Hi there
I just one to confirm one thing. If I’m using r.resamp.stats with mode option. If the most frequent value is a null, will i have a null value in the ouput?
Thank you
Kat
Hi there
Thank you
Kat
katrin eggert wrote:
I just one to confirm one thing. If I'm using r.resamp.stats with
*mode *option.
No.
With the -n option, the output is null if any input cell is null.
Without the -n option, most aggregates (including "mode") ignore null
cells; you'll only get a null result if all input cells are null.
IIRC, the only reason that nulls are retained in the array passed to
the aggregate functions is that some of them (e.g. interspersion,
regression) consider the cell's position within the array, and having
the caller discard nulls beforehand would interfere with this.
Just one question: is it possible to “count” number of cells with a certain value (or nulls) from one scale that are being used to calculate each value pixel of the target scale?
Thanks
2011/6/22 Glynn Clements <glynn@gclements.plus.com>
*mode *option.
If the most frequent value is a null, will i have a null value in the ouput?No.
Without the -n option, most aggregates (including “mode”) ignore null
cells; you’ll only get a null result if all input cells are null.IIRC, the only reason that nulls are retained in the array passed to
regression) consider the cell’s position within the array, and having
the caller discard nulls beforehand would interfere with this.–
Just one question: is it possible to "count" number of cells with a certain
Not directly, but you can create a binary (0/1 or null/1) version of
the input map then use "r.resamp.stats method=sum ..." on that.
