Hello!!!
I’m new user on GRASS and I’m trying to execute the addon v.centerline on GRASS 7.9. As input I’m using a shapefile containing line (MultiLineString) as geometry and when I have run the v.centerline an erro is returning:
“Traceback (most recent call last):
File "C:\Users\cesar\AppData\Roaming\GRASS7\addons/scripts
/v.centerline.py", line 319, in
main()
/v.centerline.py", line 111, in main
segment_input += 'P ’ + category.strip()
TypeError: can only concatenate str (not “bytes”) to str
(Wed Mar 4 17:27:25 2020) Comando terminado (3 segundos)
v.centerline input=Linha_rio_teste_Centerline@PERMANENT output=teste range=2 refline=2
main()
(Wed Mar 4 17:27:28 2020) Comando terminado (2 segundos)”
I would like help to try understand what’s happening.
Regards.
César de Paula
