Hello,
any idea why v.db.select works while db.select fails when invoked from inside the same mapset?
I call db.connect -p before calling (v.)db.select and get:
driver:odbc
database:3drov
schema:(null)
group:(null)
This all works fine for v.db.select but db.select fails with an error message. My version of GRASS is 6.2.3 and the error message reads:
DBMI-ODBC driver error: SQLConnect():
[UnixODBC]FATAL: role '' does not exist (210)
Now, I am pretty confident that unixODBC is correctly configured on my Linux box as I have C code that works with the same DSN (3drov) and also, obviously, because v.db.select manages to connect to my database through the same DSN. I also made sure that the 3 in the name 3drov is not the source of the problem, but I'm now totally clueless.
Any idea why? Thanks in advance!
Sébastien E. Wailliez
Software Engineer
Trasys Space - Consulting & Solutions
Terhulpsesteenweg 6C
B-1560 Hoeilaart - Belgium
Office: 2K22
Tel: +32 2 773 75 64
Fax: +32 2 773 79 30
Email: sebastien.wailliez@trasys.be
Sébastien,
could you try ogrinfo on that data set? Just to see if it also
fails. Should be something like
ogrinfo ODBC:user/pass@DSN table
On Wed, Mar 19, 2008 at 1:30 PM, Wailliez Sébastien
<sebastien.wailliez@trasys.be> wrote:
Hello,
I call db.connect –p before calling (v.)db.select and get:
driver:odbc
database:3drov
schema:(null)
group:(null)
Software Engineer
Office: 2K22
grass-user mailing list
grass-user@lists.osgeo.org
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
