[GRASS-user] v.distance problem
Hi
v.distance is not transferring attributes and I can't figure out why. It's worked before on similar data but not this time around:
v.distance --overwrite from=route1pavementnodes@PERMANENT to=route1stands@PERMANENT to_type=area output=route1pavementnodes_conn_lines dmax=2 upload=to_attr column=stand_id to_column=stand_id
  100%
6702 categories read from the map
6702 categories exist in the table
6702 categories read from the map don't exist in the table
0 records updated
v.distance complete.
output lines are generated but no attributes transferred.
Is there some data preparation step I'm missing perhaps?
GRASS 6.4.1
Gavin
