[GRASS-user] v.net.path algorithm problem
I'm using v.net.path in a simple example:
http://n2.nabble.com/file/n4789540/Network.png
http://n2.nabble.com/file/n4789540/Network.png Network.png
In my example I calculate the shortest path from all green dots (101, 102,
103) to all grey squares (1, 2, 3,...).The nodes are piped in with a
textfile:
1 101 1
2 101 2
3 101 3
4 101 4
5 101 5
6 101 6
7 101 7
8 101 8
9 101 9
10 101 10
11 101 11
12 102 1
13 102 2
14 102 3
15 102 4
16 102 5
It seems to me, that the algorithm has some problems. It can not find a path
for all combinations. I get the following warning:
WARNING: Point with category [7] is not reachable from point with category
         [102]
WARNING: Point with category [8] is not reachable from point with category
         [102]
WARNING: Point with category [9] is not reachable from point with category
         [102]
WARNING: Point with category [10] is not reachable from point with category
         [102]
WARNING: Point with category [11] is not reachable from point with category
         [102]
WARNING: 5 destination(s) unreachable (including points out of threshold)
The strange thing is, that after inserting an additional node combination
(999 101 1) twice into the textfile around the prolematic points, the paths
can be generated without warnings or errors.
So the unproblematic textfile looks like this:
15 102 4
16 102 5
17 102 6
999 101 1
18 102 7
19 102 8
999 101 1
20 102 9
21 102 10
22 102 11
23 103 1
24 103 2
Also calculating only a single problematic path (e.g 18 102 7) is working
fine.
Does anyone of you know, what could cause this strange behaviour? How does
the order of the nodes influence the algorithm?
Greetings Schorschli
View this message in context: http://n2.nabble.com/v-net-path-algorithm-problem-tp4789540p4789540.html
On Wed, Mar 24, 2010 at 8:45 AM, schorschli <matthiasoswald@hotmail.com> wrote:
textfile:
1 101 1
2 101 2
3 101 3
4 101 4
5 101 5
6 101 6
7 101 7
8 101 8
9 101 9
10 101 10
11 101 11
12 102 1
13 102 2
14 102 3
15 102 4
16 102 5
[102]
[102]
[102]
[102]
[102]
Perhaps some nodes are missing? I have success in the past by applying
http://grass.osgeo.org/grass64/manuals/html64_user/v.net.html
to the map.
