Trying to convert the attribute database of a vector (points) table from
dbf to postgres, and I'm missing a critical step.
Asked and answered:
GRASS 6.5.svn (Washington-Kinross):~/grassdata > v.db.connect
map=surface_h2o -p
Vector map <surface_h2o@buckhorn> is connected by:
layer <1> table <suface_water_sites> in database
</home/rshepard/grassdata/Washington-Kinross/buckhorn/dbf/> through driver
<dbf> with key <cat>
Used v.out.ogr to export from dbf to a postgres table emulating the
example on the manual page:
The example's syntax is:
Export to PostgreSQL/PostGIS
Export areas from GRASS vector map directly to PostGIS:
v.out.ogr input=polygons type=area \
dsn="PG:host=localhost dbname=postgis user=postgres" \
olayer=polymap format=PostgreSQL
so I try,
GRASS 6.5.svn (Washington-Kinross):~/grassdata > v.out.ogr in=surface_h2o
type=point dsn="PG:dbname=buckhornmine"
Exporting 13 geometries...
100%
v.out.ogr complete. 13 features written to <surface_h2o> (ESRI_Shapefile).
and end up with a directory called PG\:dbname\=buckhornmine/ containing the
shapefile.
What command line do I use to transfer the attributes from the native dbf
to a postgres table in the defined database?
Rich
hellik
March 22, 2012, 8:35pm
2
v.out.ogr - Converts GRASS vector map to one of the supported OGR vector
formats.
v.out.ogr export the entire vector map (geometry and attribute) not only the
attribute table
from the manual:
http://grass.osgeo.org/grass64/manuals/html64_user/v.out.ogr.html
missing format definition?
default format is shape-file
what I would do (a very lazy way):
- create a new mapset
- using db.connect (Prints/sets general DB connection for current mapset and
exits.) to define postgres as the mapset database backend
- g.copy surface_h2o to the new mapset and the attribute table should be
automagically in the postgres
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/v-out-ogr-Convert-Attribute-Database-tp4645995p4646386.html
Helmut,
Er, looks like I did forget the format definition.
I'll give this a try. I can then delete the original map and copy the new
one back to the project mapset.
Will let everyone know how this works.
Rich
Sigh. Adding the format=PostgreSQL did the trick. Guess I needed more
caffine before lunch so as not to miss a critical option.
Again, many thanks,
Rich
