I'm trying to run the v.rast.stats script using a vector map and a dem as
input.
The strange thing is, that for one vector map the script works fine, and for
another vector map I get the error "No categories found in raster map". As
far as I understood, this error is related to the vector map, not the raster
map due to the following lines in the v.rast.stats script. So, I thought
this might be related to a bad topology of the vector map. But even a test
case with only 1 polygon gives me the "No categories found" error. I checked
the vector maps, but in every map I have categories and centroids.
Does anybody know how to resolve this problem?
Thanks a lot,
Sonja
#prepare raster MASK
v.to.rast in="$VECTOR" out="${VECTOR}_${TMPNAME}" use=cat --quiet
if [ $? -ne 0 ] ; then
g.message -e "An error occurred while converting vector to raster"
cleanup
exit 1
fi
#dump cats to file to avoid "too many argument" problem:
r.category "${VECTOR}_${TMPNAME}" fs=';' --quiet | cut -d';' -f1 >
"$TEMPFILE.cats" #echo "List of categories found: $CATSLIST"
NUMBER=`cat "$TEMPFILE.cats" | wc -l | awk '{print $1}'`
if [ $NUMBER -lt 1 ] ; then
g.message -e "No categories found in raster map"
cleanup
exit 1
fi
On Fri, Nov 26, 2010 at 2:22 PM, sonja1 <sonja.jankowfsky@cemagref.fr> wrote:
input.
Try to set the region to the vector, align it to the raster you want to query
g.region vect=vector align=raster
Markus M
cleanup
exit 1
fi
cleanup
exit 1
fi
input.
Markus M
cleanup
exit 1
fi
cleanup
exit 1
fi
