Here's a text file I prepared for use as stdin for v.segment:
P 1 2 100 100
P 2 2 200 100
P 3 2 300 100
P 4 2 400 100
The fourth column, according to the v.segment html page, is the orthogonal
offset from the input vector. But no matter what I make this value, the
output vector is never offset, it's always in the middle of the width of the
line. What am I doing wrong here?
~ Eric.
P 1 2 100 100
P 2 2 200 100
P 3 2 300 100
P 4 2 400 100
Maybe nothing (not sure):
http://grass.itc.it/pipermail/grassuser/2005-December/031522.html
">> What does the extra, optional value <side offset> in v.segment stands for?
> The point placed in the give distance form the line.
>> I couldn't get any differences by using this!
> That would be bug, are you sure you use appropriate zoom
> for given distance.
It still doesn't work ...
I don't see any answer from Radim.
with
g.gisenv set="DEBUG=2"
you should see some related output how the file is parsed.
In the code I don't see that side_offset modifies offset1 or
offset2 (which it probably should).
