[GRASS-user] v.vol.rst error
Hello all,
I would like to use the v.vol.rst module but when I try to execute them from the GRASS GUI this error text appears in the terminal:
GRASS 6.4.0RC4 (costabrava):~ > *** buffer overflow detected ***: v.vol.rst terminated
======= Backtrace: =========
/lib/tls/i686/cmov/libc.so.6(__fortify_fail+0x48)[0xb7792da8]
/lib/tls/i686/cmov/libc.so.6[0xb7790eb0]
/lib/tls/i686/cmov/libc.so.6[0xb77905a8]
/lib/tls/i686/cmov/libc.so.6(__overflow+0x53)[0xb7703683]
/lib/tls/i686/cmov/libc.so.6(__printf_fp+0x176e)[0xb76db26e]
/lib/tls/i686/cmov/libc.so.6(_IO_vfprintf+0x3ca)[0xb76d4bfa]
/lib/tls/i686/cmov/libc.so.6(__vsprintf_chk+0xa4)[0xb7790654]
/lib/tls/i686/cmov/libc.so.6(__sprintf_chk+0x2d)[0xb779059d]
v.vol.rst(main+0x176)[0x804c966]
/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe5)[0xb76ab775]
v.vol.rst[0x804bd71]
======= Memory map: ========
08048000-08056000 r-xp 00000000 08:06 347205 /usr/lib/grass64/bin/v.vol.rst
08056000-08057000 r–p 0000d000 08:06 347205 /usr/lib/grass64/bin/v.vol.rst
08057000-08058000 rw-p 0000e000 08:06 347205 /usr/lib/grass64/bin/v.vol.rst
08a25000-08a46000 rw-p 08a25000 00:00 0 [heap]
Anybody know how to fix that?
Pd: My GRASS version is GRASS 6.4.0RC4 (2009) runnig on UBUNTU 9.04
Celebramos el 10º aniversario de Messenger. ¡Únete a la fiesta!
On Mon, Aug 31, 2009 at 7:26 PM, xavier garcia
acosta<epistacio@hotmail.com> wrote:
Hello all,
terminated
08056000-08057000 r--p 0000d000 08:06 347205
I have used v.vol.rst in GRASS 6.4 for more than 22000 UTM maps
without problems.
Please tell use the parametes you used (idealy the command line), or,
even better, an example to reproduce it with either Spearfish or the
North Carolina
data set. Which projection?
Date: Mon, 31 Aug 2009 22:42:05 +0200
Subject: Re: [GRASS-user] v.vol.rst error
To: epistacio@hotmail.com
CC: grass-user@lists.osgeo.org
acostaepistacio@hotmail.com wrote:
Hello all,
terminated
without problems.
North Carolina
The fact is that I had just tried to execute this module from the GRASS GUI, without include any parameter. Then I have tried execute the module in the terminal and the result is exactly the same, with or without parameters:
GRASS 6.4.0RC4 (costabrava):~ > v.vol.rst input=string [cellinp=dtm] [wcolumn=DIESPLUJA] [cellout=diespluja]
/lib/tls/i686/cmov/libc.so.6(__fortify_fail+0x48)[0xb77d0da8]
/lib/tls/i686/cmov/libc.so.6[0xb77ceeb0]
/lib/tls/i686/cmov/libc.so.6[0xb77ce5a8]
/lib/tls/i686/cmov/libc.so.6(__overflow+0x53)[0xb7741683]
/lib/tls/i686/cmov/libc.so.6(__printf_fp+0x176e)[0xb771926e]
/lib/tls/i686/cmov/libc.so.6(_IO_vfprintf+0x3ca)[0xb7712bfa]
/lib/tls/i686/cmov/libc.so.6(__vsprintf_chk+0xa4)[0xb77ce654]
/lib/tls/i686/cmov/libc.so.6(__sprintf_chk+0x2d)[0xb77ce59d]
/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe5)[0xb76e9775]
08efe000-08f1f000 rw-p 08efe000 00:00 0 [heap]
b5a1b000-b5a5a000 r–p 00000000 08:06 81613 /usr/lib/locale/ca_ES.utf8/LC_CTYPE
b5a5a000-b5a5e000 rw-p b5a5a000 00:00 0
b5a5e000-b5a61000 r-xp 0
My projection is: 1 (UTM)
zone: 31
datum: eur50
Xavier
To: grass-user@lists.osgeo.org
Subject: RE: [GRASS-user] v.vol.rst error
Date: Tue, 1 Sep 2009 08:03:27 +0000
Hello all,
terminated
without problems.
North Carolina
I have solved the last problem but now when I exectute v.vol.rst module with the next command:
v.vol.rst input=puntsestacio@pobles cellinp=dtm@clima wcolumn=DIESPLUJA tension=40. smooth=0.1 segmax=700 npmin=200 dmin=15.001074 wmult=1.0 zmult=1.0 cellout=diespluja2
I’ve got the next error:
“Percent complete: WARNING: Reading raster map dtm@clima request for row 3231 is outside region
ERROR: Could not get row (eventually WIND3 does not match WIND)”
Anybody know how to solve that?
Messenger cumple 10 años ¡Descárgate ya los nuevos emoticonos!
On Tue, Sep 1, 2009 at 10:03 AM, xavier garcia
b5a1b000-b5a5a000 r--p 00000000 08:06 81613
I have tried with 6.4.svn in the Slovakia3d demo location:
v.vol.rst precip3d cellinp=precip wcolumn=precip cellout=diespluja segmax=700
435 records selected from table
WARNING: strip exists with insufficient data
Processing all selected output files will require 0 bytes of disk space for
temp files
Percent complete: 0%...
I didn't wait for 100% though. Does it crash immediately for you?
On Tue, Sep 1, 2009 at 5:50 PM, xavier garcia
the next command:
I've got the next error:
"Percent complete: WARNING: Reading raster map <dtm@clima> request for row
ERROR: Could not get row (eventually WIND3 does not match WIND)"
Check
g.region -p3
if rows and rows3 match and col and cols3. They need to be adjusted if not.
Date: Fri, 4 Sep 2009 20:30:30 +0200
temp files
Percent complete: 0%…
I didn’t wait for 100% though. Does it crash immediately for you?
the next command:
Check
g.region -p3
I did it and now v.vol.rst doesn’t crash. The problem now is that I got a NULL data output. I have tried Slovakia3d demo location and it works properly so I suspect that the problem is a lack o data points in my location.
Xavier
Con Vodafone disfruta de Hotmail gratis en tu móvil. ¡Pruébalo!
