I'm unable to figure out how to query vector attribute tables on my Mac using
the sample North Carolina data. I'm trying to query one of the vector files
has a column "CANCER" with attributes 'yes' or 'no'.
What I'm doing:
1. Choose Vector > Query with Attributes
2. In the v.extract window that opens...
- On the Options tab I choose my input vector map and type a name for an
output vector
- On the Selection tab, in the "Where conditions of SQL statement..." field,
I type in my query, "CANCER=yes"
3. I click Run
In the output window,
I get the following error:
DBMI-DBF driver error:
Column 'yes' not found
Incompatible types in WHERE condition.
Error in selecting rows
Error in db_open_select_cursor()
Is there a db/SQL issue with GRASS on a Macintosh? If so, can it be fixed?
Why would it think "yes" is a column instead of an attribute?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Vector-attribute-query-errors-on-a-Mac-tp5365200p5365200.html
