Hi, im new in grass and im trying to create a vector map from scratch and/or with a raster as background, but i cant get the gui of v.digit to work… how does it work?..
thank you !!
Isabel Alfaro Cardozo
thank you !!
Hi Isabel
too few informations...
which grass are you using?
with which OS?
did you try to type "v.digit&" on the shell?
this usually calls the v.digit gui...
bye
Il giorno gio, 01/11/2007 alle 11.31 -0400, Isabel Alfaro Cardozo ha
scritto:
to work... how does it work?..thank you !!
grassuser mailing list
grassuser@grass.itc.it
Ti prego di cercare di non inviarmi files .doc, .xls, .ppt, .dwg.
Preferisco formati liberi.
Please try to avoid to send me .doc, .xls, .ppt, .dwg files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
e-mail: marchesini@unipg.it
ivan.marchesini@gmail.com
tel: +39(0)755853760
fax (university): +39(0)755853756
fax (home): +39(0)5782830887
jabber: geoivan73@jabber.org
Hi!
If you want to load a raster as a background (for example) do:
1. d.mon x? (with this you start an "x"-monitor --- Where ? substitute with
a number 0,1,2,3,...)
2. Load a specific raster with d.rast "name-of-raster-file"
3. Use v.digit now and run the "digitising" dialog.
Shouldn't be so difficult as it looks like.
In any case, it is recommended, from my small experience, to read the help
for the respective command you want yo use (e.g. man v.digit).
ivan marchesini wrote:
Hi Isabel
with which OS?did you try to type "v.digit&" on the shell?
bye
scritto:Hi, im new in grass and im trying to create a vector map from scratch
http://grass.itc.it/mailman/listinfo/grassuser--
http://en.wikipedia.org/wiki/Open_formatIvan Marchesini
Via G. Duranti 93/a
06125
Perugia (Italy)
http://www.gfoss.it
jabber: geoivan73@jabber.org_______________________________________________
View this message in context: http://www.nabble.com/vector-map-tf4732172.html#a13561095
