On Tue, 30 May 2006 22:10:42 +0200
Wolfgang <wollez@gmx.net> wrote:
sorry, but I still don't understand the vector/database handling of
grass completely. At the moment I use dbf files, but this seems not
to be very flexible. It seems also that not all vector data is stored
in the dbf files.
Only attributes of vector features (point,line,centroid etc.) are
stored in the table (no matter what DB backend in Grass).
Note that a feature to have an entry in the table has got to have a
category first (see v.category).
When I import for example a shapefile into grass,
are all nodes of the lines imported to dbf?
No. One line is one, whole vector feature. If you need each node to have
separate table entry, use v.to.points -v, then v.to.db.
I think no because I have
an other folder on my computer which is called "vector" but what are
the files "cidx,coor,dvln,head,hist,topo"?
As you can see, I'm really confused, what this database stuff is for
when all data is still stored somewhere else.
I hope that somebody can help me and explain me the idea of
vector/database handling.
v.in.ogr, as well as many other Grass modules that output a new vector
layer, will setup categories for features and upload them into a key
"CAT" column (it could be any other name though, see v.db.connect)
along with their attributes respectively.
Read your grass-6.1.cvs/docs/html/vectorintro.html too.
I hope it helps.
Best,
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
