Looking at the web site's source download page I see that the svn trunk
was changed last month to 7.7svn. Removing the ~/gis/grass/grass7_trunk/
directory and running "svn checkout https://svn.osgeo.org/grass/grass/trunk
grass7_trunk" then building from scratch and installing the latest release
(73393?) I expected to see the new 7.7 version when I started grass.
However, I still see:
$ grass --version
GRASS GIS 7.5.svn
And starting grass shows:
Welcome to GRASS GIS 7.5.svn (exported)
and
GRASS 7.5.svn :~/data/grassdata >
When I run 'find / -name grass-7.5' nothing is found.
What changes these version displays with the new build?
Rich
Rich,
In my system the executables for the different grass versions look like this:
grass74
grass75
grass77
There was no confusion when updating the svn trunk (grass7_trunk).
I guess that the problem will disappear if you delete the installed executable, the installed grass folder, and then make a new fresh install.
/H.
$ grass --version
GRASS GIS 7.5.svn
and
Rich
grass-user mailing list
grass-user@lists.osgeo.org
grass74
grass75
grass77
Hernán,
A while ago I copied /usr/local/bin/grass75 to /usr/local/bin/grass and
used only 'grass' on the command line, so it was the executable for 7.5.svn
that ran.
Cleaned this up now (no more 'grass') and this morning's build, 'grass77'
now loads properly at the command line.
I should have seen this earlier. Thanks for pointing out the obvious.
Best regards,
Rich
* Rich Shepard <rshepard@appl-ecosys.com> [2018-09-22 10:30:35 -0700]:
grass74
grass75
grass77
Hernán,
that ran.
Maybe better to softlink, instead of copying.
Nikos
[rest deleted]
