[GRASS-user] wget (corine) "landcover_tiles_v2" for greece works, but not for europe(?)
# get GR_100K.shp which is GREEA18328I.zip [1] from [2]
# under the column "CellCode" are listed all tiles (in this case all
tiles which cover Greece) with their exact name.
#v.db.connect -p
## if requiredδημιουργία της σύνδεσης αν δεν υφίσταται
# db.connect driver=sqlite
database=/geo/grassdb/ellas/laea/PERMANENT/sqlite.d
# import GR_100K.shp
v.in.ogr dsn=/geo/geodata/europe/GREEA18328I/GR_100K.shp
out=eea_gr_100k --o
# check newly imported table
db.select eea_gr_100k
cat|CellCode|EofOrigin|NofOrigin
1|100kmE51N18|5100000|1800000
2|100kmE51N19|5100000|1900000
3|100kmE52N16|5200000|1600000
4|100kmE52N17|5200000|1700000
5|100kmE52N18|5200000|1800000
6|100kmE52N19|5200000|1900000
7|100kmE52N20|5200000|2000000
8|100kmE53N15|5300000|1500000
9|100kmE53N16|5300000|1600000
10|100kmE53N17|5300000|1700000
# create file with tiles-list
db.select eea_gr_100k -c | cut -d"|" -f2 > corine_tiles_ellas
100kmE51N18
100kmE51N19
100kmE52N16
100kmE52N17
100kmE52N18
100kmE52N19
# wget within a for loop
for x in `cat corine_tiles_ellas`; do wget
http://dataservice.eea.europa.eu/staticfiles/landcover_tiles_v2/$x.zip;
done
--2009-01-12 15:12:26--
http://dataservice.eea.europa.eu/staticfiles/landcover_tiles_v2/100kmE51N18.zip
Resolving dataservice.eea.europa.eu... 217.74.209.209
Connecting to dataservice.eea.europa.eu|217.74.209.209|:80...
connected.
HTTP request sent, awaiting response... 200 OK
Length: 408346 (399K) [application/x-zip-compressed]
Saving to: `100kmE51N18.zip'
100%
[============================>] 408,346 1.12M/s in 0.3s
2009-01-12 15:12:27 (1.12 MB/s) - `100kmE51N18.zip' saved
[408346/408346]
Now, if I try to repeat this process for the whole of europe (based on
the file Grid_ETRS89_LAEA5210_100K), I only get 31KB files which are
corrupted (?) and anyway, they are to small to carry any information.
What could be the reason?
Thanks, Nikos
[1] http://dataservice.eea.europa.eu/download.asp?id=18328&filetype=.zip
[2] http://dataservice.eea.europa.eu/dataservice/metadetails.asp?id=760
[3] http://dataservice.eea.europa.eu/download.asp?id=16267&filetype=.zip
#v.db.connect -p
out=eea_gr_100k --o
100kmE51N18
100kmE51N19
100kmE52N16
100kmE52N17
100kmE52N18
100kmE52N19
done
connected.
100%
[408346/408346]
the file Grid_ETRS89_LAEA5210_100K[3]), I only get 31KB files which are
(Answerting to myself :wink:
It's simple. The attribute table of Grid_ETRS89_LAEA5210_100K holds lots
of "empty cells" since it covers a huge rectangular (a total of more
than 8000 boxes if I remember well).
I downloaded each country's 100k-eea-reference-grid shapefile, imported
all in grass and exported a "european non-empty" list (file attached -
around 1300 boxes). I re-run the wget-for loop and everything works
fine :slight_smile:
(attachments)
corine_v2_tiles_list_europe (15.9 KB)
fine :slight_smile:
Something is wrong... While my list has no double entries (I
cross-checked with "sort -u" the output of "db.tables -p"), wget
downloaded 262 tiles two times, another 56 tiles three times and another
8 tiles four times!!
Why is that? Connection problems? Most of the double files have the same
size.
Here how I go about it (for all available reference-grid shapefiles):
# check per-country 100k reference-grid-cells
db.tables -p | grep -v grid
AL_100k
AT_100k
BA_100k
BE_100k
BG_100k
CH_100k
CY_100k
CZ_100k
DE_100k
DK_100k
EE_100k
ES_100k
FI_100k
FR_100k
GR_100k
HR_100k
HU_100k
IE_100k
IS_100k
IT_100k
LT_100k
LV_100k
ME_100k
MK_100k
NL_100k
NO_100k
PL_100k
PT_100k
RO_100k
RS_100k
SE_100k
SI_100k
SK_100k
TR_100k
UK_100k
# count tiles from attribute tables
for x in `db.tables -p | grep -v grid`; do db.select -c $x | cut -d"|"
-f2; done | wc -l
1362
# cross-check for double entries
## but, is this possible in a "clean" geo-attribute table after all?
-f2 | sort -u; done | wc -l
1362
# create a tiles-list
-f2; done > corine_v2_tiles_list_europe
# get tiles
for x in `cat corine_v2_tiles_list_europe`; do wget
-a wget_corine_v2_tiles_europe.log && echo "Tile $x downloaded"; done
## unfortunately I used the log in the wrong way initially: instead of
"-a" I used "-o" which overwrites for each loop an existing log :frowning:
# check results
# total number of downloaded tiles agrees with the above mentioned count
# but... there a lot of double- and triple-downloaded tiles.
Any clue what's messing up this attempt?
Ah, something important I forgot: many thanks to Markus for pointing out
to "wget" and Dimitris Zachariadis for pointing to the
address.
Nikos
