While re-projecting a vector map this warning appears:
WARNING: Coor file of vector map <highest_hit_contours@topography> is
larger than it should be (840663845 bytes excess)
What might cause this warning?
Rich
Rich
On Thu, Sep 29, 2016 at 11:51 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
larger than it should be (840663845 bytes excess)What might cause this warning?
The vector map was not closed properly when it was created. This can
happen when a module creating a new vector map crashes before it
closes the vector.
Markus M
happen when a module creating a new vector map crashes before it closes
the vector.
Markus,
Thanks for explaining.
Rich
