[GRASS-user] Which EPSG code for location default?
Applying gdalsrsinfo to a shapefile's .prj produced these results:
PROJ.4 : +proj=utm +zone=10 +datum=NAD83 +units=m +vunits=m +no_defs
OGC WKT2:2018 :
COMPOUNDCRS["NAD83 / UTM zone 10N + NAVD88 height",
     PROJCRS["NAD83 / UTM zone 10N",
         BASEGEOGCRS["NAD83",
             DATUM["North American Datum 1983",
                 ELLIPSOID["GRS 1980",6378137,298.257222101,
                     LENGTHUNIT["metre",1]],
                 ID["EPSG",6269]],
             PRIMEM["Greenwich",0,
                 ANGLEUNIT["Degree",0.0174532925199433]]],
         CONVERSION["UTM zone 10N",
             METHOD["Transverse Mercator",
                 ID["EPSG",9807]],
             PARAMETER["Latitude of natural origin",0,
                 ANGLEUNIT["Degree",0.0174532925199433],
                 ID["EPSG",8801]],
             PARAMETER["Longitude of natural origin",-123,
                 ID["EPSG",8802]],
             PARAMETER["Scale factor at natural origin",0.9996,
                 SCALEUNIT["unity",1],
                 ID["EPSG",8805]],
             PARAMETER["False easting",500000,
                 LENGTHUNIT["metre",1],
                 ID["EPSG",8806]],
             PARAMETER["False northing",0,
                 ID["EPSG",8807]],
             ID["EPSG",16010]],
         CS[Cartesian,2],
             AXIS["(E)",east,
                 ORDER[1],
                 LENGTHUNIT["metre",1,
                     ID["EPSG",9001]]],
             AXIS["(N)",north,
                 ORDER[2],
                     ID["EPSG",9001]]]],
     VERTCRS["NAVD88 height",
         VDATUM["North American Vertical Datum 1988"],
         CS[vertical,1],
             AXIS["gravity-related height (H)",up,
                     ID["EPSG",9001]]]]]
The data are the Columbia River and southern Washington state.
It's been a couple of decades since I last dug into proj and I'd appreciate
being pointed to a document that will teach me which of the several EPSG
codes above is the one to which I want to apply to PROJ_INFO in the
PERMANENT mapset.
TIA,
Rich
Hi Rich,
Taking a look at your output, my brain said "good question", ha.
Usually the key line to look for is the "AUTHORITY:" line, which yours lacks.
So the usual next step is to start searching on https://epsg.io for the text "UTM zone 10N".
But more recently the official EPSG homepage includes a search tool that does a live search on its own database (giving guaranteed accurate/uptodate responses):
- goto https://epsg.org
- click the top menu: EPSG Dataset/Text Search
- enter: UTM zone 10N and press "Go"
- gives a response of 12 items
EPSG:26910 does look somewhat similar :slight_smile:
Hope that gives you some hints... (at least on the official EPSG code perspective)
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
OGC WKT2:2018 :
ID["EPSG",6269]],
ID["EPSG",9807]],
ID["EPSG",8801]],
ID["EPSG",8802]],
ID["EPSG",8805]],
ID["EPSG",8806]],
ID["EPSG",8807]],
ID["EPSG",16010]],
CS[Cartesian,2],
AXIS["(E)",east,
ORDER[1],
ID["EPSG",9001]]],
AXIS["(N)",north,
ORDER[2],
ID["EPSG",9001]]]],
CS[vertical,1],
ID["EPSG",9001]]]]]
PERMANENT mapset.
TIA,
Rich
grass-user mailing list
grass-user@lists.osgeo.org
It could also be that no one yet has submitted this to the EPSG geodetic committee, for inclusion (UTM zone 10N with that vertical datum). *hint* *maybe you should* (PS I've submitted several, just use the mindset "well someone has to")
So.....all of my answers to you are very unhelpful, ha.
But that's all I've got for you now.
-jeff
Jeff McKenna
Jeff,
There are so many value-specific codes I didn't see an overall code.
Ah-ha. That's good information.
I'll check for myself; I had the impression that all EPSG codes were four
digits.
It certainly does.
Thanks very much,
Rich
Jeff,
Interesting. Actually, since this project (like all of them) have data
sources using different projections I don't care which is used as long as I
can reproject data from the source to a single appropriate one. I could use
Washington State Plane (South) and that would work just as well,
Not at all.
And that's good enough.
Yet, ... I have a question: is there a way in grass to change the PROJ_INFO
in the PERMANENT mapset of a location to a new projecion? Or, do I manually
edit that file?
Thanks in advance,
Rich
edit that file?
IMHO you should *not* do that. Just create a new Location.
Thanks in advance,
Rich
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
https://orcid.org/0000-0002-1128-1325
Micha,
I thought that would be the answer. Then I need to reproject all data at
least twice, then rename the new location.
Rich
Jeff,
Thanks for excellent advice. I decided to be consistent and use the
NAD83(HARN)/meters EPSG for Washington South to be consistent with what I've
used in other projects and other states. That EPSG code is 2856.
Now I'll create a new location with that projection and reproject all
imported maps to that location and rename it to the project's location name.
I think it was in the late 1980s-early 1990s that I used UTM zones before
switching to State Plane Coordinates. On this project the first data set I
imported used UTM Zone 10 and I stuck with it ... until now.
Rich
