Dear grass users
I succeeded in installing d.barb the other day.
Because d.barb was very wonderful addon, I tried installing to other PC.
However, I fail in the installation....
I tried on the following conditions.
(Case 1) ubuntu11.04 wubi version on Windows7
---> Success
(Case 2) ubuntu10.04 vmware version on Windows X
---> failed
(Case 3) lubuntu11.04 vmware version on Windows 7
---> failed
In Case 2 and 3, the same error message is output as follows.
The log might not be read easily for you in a Japanese mode...
--- begin message ---
GRASS 6.4.1 (newLocation_5):/home/shimada > g.extension extension=d.barb
Fetching <d.barb> from GRASS-Addons SVN (be patient)...
A d.barb/legend.c
A d.barb/local_proto.h
A d.barb/main.c
A d.barb/description.html
A d.barb/grid.c
A d.barb/Makefile
A d.barb/points.c
A d.barb/draw.c
U d.barb
リビジョン (revision )46793 をチェックアウト(checkout)しました。
Compiling <d.barb>...
/usr/lib/grass64/include/Make/Grass.make:418: 警告(warning): ターゲット(target
) `/usr/lib/grass64/bin' へのコマンド(command)を置き換えます(replace)
/usr/lib/grass64/include/Make/Grass.make:409: 警告(warning): ターゲット(target
) `/usr/lib/grass64/bin' への古いコマンド(old command)は無視されます(ignore)
make: `/usr/lib/grass64/dist.i486-pc-linux-gnu' に対して行うべき事はありません
Installing <d.barb>...
You need to enter the root password next to install d.barb:
/usr/lib/grass64/include/Make/Grass.make:418: 警告(waring): ターゲット(targe)
/usr/lib/grass64/include/Make/Grass.make:409: 警告(warning): ターゲット(taget)
/usr/bin/install -c /usr/lib/grass64/bin/d.barb /usr/lib/grass64/bin/
/usr/bin/install: `/usr/lib/grass64/bin/d.barb' を stat できません(can not): N
o such file or directory
make: *** [install] エラー 1 (error 1)
エラー(error): Installation failed, sorry. Please check above error messages.
---- end of message ---
I don't understand that though there is '/usr/lib/grass64/bin/', error messege
'can not stat' output..
I tried all cases by user and root(su).
I changed to permission of '/usr/lib/grass64/' from read only to read and writ
e . Of course,
I also corrected two make files in all casees;
/usr/lib/grass64/make
Platform.make
Grass.make
http://www.mail-archive.com/grass-user@lists.osgeo.org/msg16723.html
I want you to give profitable information by all means...
Or, please teach other installation method.
Best
Yasuo SHIMADA
