[GRASS-user] Wingrass Raster Layer Manager issue
Dear List,
I am having trouble with the Layer Manager in winGRASS 6.4.3.1 downloaded from (http://grass.osgeo.org/grass64/binary/mswindows/native/). This is a PC running Windows 7.
The problem is that when I want to add a raster or vector layer, that separate window that needs to pop up is not coming. Rather, the Layer Manager creates a layer with no name. I tried to use the “rename” option by right clicking. I types the name of the map but it dis not work. I also could not remove the layer.
I downloaded and installed the same application package on a different PC with the same OS and I did not have the issue. This suggests to me that this is an issue about the computer I am using. I have not seen anything like that. Am I missing an additional file? Should I download and install .NET Framework (although, GRASS launches fine).
Thank you,
BÜLENT
Hi Bülent,
can you check the Command console tab in the Layer Manager which is the second item from the left at the bottom of Layer Manager window? There might be an error message in there. You may also check the (black) windows command line.
The layer with the label “raster (double click to change properties)” is created immediately when you press the “Add raster map layer” button. If there is no text, it is a problem.
This seems that this will be hard to reproduce, so it would be great help if you double check all consoles, all opened windows, try this with nightly build of GRASS 7, do some screenshots (1)… it’s hard to say what is important. For now it could be enough if you just check the Command console.
Vaclav
(1) You may want to send the screenshots only to me, to avoid file size limit check in the mailing list.
On Thu, Oct 10, 2013 at 4:04 AM, Bulent Arikan <bulent.arikan@gmail.com> wrote:
Dear List,
Thank you,
BÜLENT
grass-user mailing list
grass-user@lists.osgeo.org
Thank you for your response and suggestions. I figured it out soon after I posted the question. Although GRASS launched fine, it was missing .NET framework. I installed v 4.5 of that and it works now!
Thank you again!
BÜLENT
On Oct 10, 2013, at 7:45 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Hi Bülent,
Vaclav
Dear List,
Thank you,
BÜLENT
These libraries (MS runtime libraries) should be installed by GRASS installer, however they are installed only when you request that (for legal/licence reasons). The checkbox is at one of the installer wizard pages (the one with installation of sample dataset).
On Thu, Oct 10, 2013 at 12:48 PM, Bulent Arikan <bulent.arikan@gmail.com> wrote:
Thank you again!
BÜLENT
Hi Bülent,
Vaclav
Dear List,
Thank you,
BÜLENT
