I compiled GRASS 6.1 CVS for pdaXrom (http://www.pdaxrom.org/) for a Zaurus PDA, and am getting the following error:
Hit RETURN to continue
Starting GRAS …
WARNING: The wish command does not work as expected!
Please check your GRASS_WISH environment variable.
Use -help option for details.
Switching to text based interface mode.
Hit RETURN to continue.
/usr/lib/grass/set_data: /lib/libc.so.6: version ‘GLIBC_2.3’ not found (required by /usr/lib/grass/lib/libgrass_gis.so)
Any ideas how I should go about this?
I’m trying to simplify the process of getting GRASS running on a Zaurus PDA. pdaXrom is a Linux/X-windows based environment for the Sharp Zaurus pdas.
(http://wiki.debian.org/?GrassGISonZaurus)
Before the compiling I istalled dependencies as stated in the source’s INSTALL text file.
Thanks!
Luis E. Menoyo
U.S. Geological Survey
677 Ala Moana Blvd., Suite 415
Honolulu, HI 96813 lemenoyo@usgs.gov
808-587-2428
Is Tcl/Tk installed? Does "wish" work from the command line?
(needed for the optional GUI menus, not for plain old x-monitors)
/usr/lib/grass/set_data: /lib/libc.so.6: version 'GLIBC_2.3' not found
Is Tcl/Tk installed? Does "wish" work from the command line? (needed for the optional GUI menus, not for plain old x-monitors)
The wish command is wish8.4 on my setup. Made a wish → wish8.4. That took care of that problem.
> /usr/lib/grass/set_data: /lib/libc.so.6: version 'GLIBC_2.3' not found >> (required by /usr/lib/grass/lib/libgrass_gis.so)
>ouch.
This is were Grass61 is hanging right now. I do have /lib/libc.so.6 on the system. Any ideas how to go about solving this problem?
Any info will be greatly appreciated.
Thanks!
Luis E. Menoyo
808-587-2428
Hamish <hamish_nospam@yahoo.com>
05/11/06 07:16 PM
To
Luis E Menoyo <lemenoyo@usgs.gov>
cc
grassuser@grass.itc.it
Subject
Re: [GRASS-user] wish and other errors on start up
> Hit RETURN to continue > > Starting GRAS ...
Did you start with "grass61 -text" ?
It's trying to start the GUI version.
> WARNING: The wish command does not work as expected! > Please check your GRASS_WISH environment variable. > Use -help option for details. > Switching to text based interface mode. > > Hit RETURN to continue.
> /usr/lib/grass/set_data: /lib/libc.so.6: version 'GLIBC_2.3' not found > (required by /usr/lib/grass/lib/libgrass_gis.so)
