I have a point map of weather stations and records since about 2005. The
attribute table has 113,570 rows; each row has the station name and date as
the primary key and there are 20 attribute columns. The reason I imported
all 20 attributes is to learn how to turn this map into a spatio-temporal
vector. The data have lon-lat geographic coordinates and were reprojected to
the project location's SRS.
I'm trying to obtain attribute data for the two stations within the
project area by clicking on the point using the 'query item' button on the
map display window.
One worked fine; the other shows a clock and doesn't produce a result even
after a 5 minute wait.
Is this an unusual request of grass on a 32-bit workstation with 4G RAM?
Rich
map display window.
I used gawk to extract the mappable attributes and am using those. Time
series and spatio-temporal statistical analyses will be done in R.
Rich
Hello Rich,
The concept of time series in GRASS GIS is based on a snapshot approach, i.e., each map represents a specific date or time interval. For the vector type case, you can either split each date as a different vector map or (if, as in your case, the coordinates are always the same) put each date in a different layer of the same vector map.
To create a time series of vector maps, you would then, need to use t.* modules, esp. t.create [0] and t.register [1]. You can check the temporal intro manual page [2] for a general description of the temporal framework and the temporal data processing wiki [3] for more (raster oriented, sorry) examples.
HTH,
Vero
[0] https://grass.osgeo.org/grass75/manuals/t.create.html
[1] https://grass.osgeo.org/grass75/manuals/t.register.html
[2] https://grass.osgeo.org/grass75/manuals/temporalintro.html
[3] https://grasswiki.osgeo.org/wiki/Temporal_data_processing
El mié., 11 jul. 2018 a las 20:57, Rich Shepard (<rshepard@appl-ecosys.com>) escribió:
the project location’s SRS.
I’m trying to obtain attribute data for the two stations within the
project area by clicking on the point using the ‘query item’ button on the
map display window.
One worked fine; the other shows a clock and doesn’t produce a result even
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Vero,
Thanks for clarifying. This won't work, then, for my data.
Best regards,
Rich
