[GRASS-user] wxGUI label
Hi all
In wxGUI I'm trying labelling but not labels appears at all.
e.g.: archsites (spearfish60 location)
The command line reported at the bottom is (see image at
http://picasaweb.google.it/pcraveri/WxGUI#):
d.vect map=archsites@PERMANENT type=point,area,centroid,line,boundary
attrcol=str1 llayer=1
but no labels are rendered in map display.
The same with areas, lines, etc.
Where I'm wrong?
Paolo
On 21/11/08 12:00, Paolo Craveri wrote:
Hi all
Where I'm wrong?
Did you tick the 'attr' check box in the Optional tab ("Display" parameter) ?
Moritz
Hi Moritz,
2008/11/21 Moritz Lennert <mlennert@club.worldonline.be>:
Ooops!
I think I made a bad impression! Sorry !
Thanks
Paolo C.
Lat. 44° 39' 11.08'' N Long. 7° 23' 25.26'' E
On 21/11/08 21:24, Paolo Craveri wrote:
Hi Moritz,
Ooops!
No problem. It is quite hidden. It probably should be in the label tab...
Moritz
