The good news is : Yes Grass will compile under Mklinux.
The bad news : I'm not entirely sure how I did it. ![]()
I think all of the problems I had with the Grass code have been fixed by
about version 15. version 18 compiled except for a couple of modules.
r.binfer was one and I can remember the other.
Most of the problems seemed to be on the Mklinux side. The Grass code is a
mix of traditional C and ansi C and the compiler from DR2.1 had a lot of
problems with it I finally got a workable system with a combination of
DR.21 and about 1/3 of the code from pre-DR3. If you're running DR3 you may
not have the same problems I did BUT DR3 changed compilers from gcc to egcs
so I can't say for sure.
One key is in the file /../src421/src/CMD/head/your file ( this is a file
you create from a gereric model to instruct the compiler) the line
COMPILE_FLAGS = should read
COMPILE_FLAGS= -02 -mcpu=powerpc -fsigned-char
-02 sets the level of optimization and isn't so important
-mcpu=powerpc tells the compiler to write code for the powermac and is necessary
-fsigned-char fixes a bug in Mklinux
Good luck, if you have problems email me or post the the list and I'll look
through my notes and see if I had the same problem and found a solution.
At 3:09 PM 9/24/98, Christian Kernbach wrote:
as I remember there was a discussion about compiling grass on MkLinux some
month ago. Unfortunately I lost these mails due to a hard disk failure. So
my questions are: did someone successful compiled grass on MkLinux and if
so how you did it?Thanks in advance,
Christian
Christian Kernbach e-mail: kerniebc@sp.zrz.TU-Berlin.DE
Gruenberger Str.22
10243 Berlin
Germany
