[GRASS5] 3D boundaries in GRASS 5.7
Hallo,
I'm trying to import some ascii file, which contains 2 squares. The squares
are looking like this:
    (the numbers are x,y,z coordinates)
  133 +-----+ 233
  122 +-----+ 222
  111 +-----+ 211
  sideways:
This is no problem, but when I try to get the upper square to vertical
position, so:
  123 +-----+ 223
  122 +-----+ 222
  111 +-----+ 211
  sideways:
and enven when I try to get to be inclined to the other site:
  113 +-----+ 213
  122 +-----+ 222
  111 +-----+ 211
  sideways:
v.in.ascii does not import them correctly (Number of incorrect boundaries : 7)
This problem is _only_ by boundaries, lines are working without problem.
I'm sending the ascii file, ready to be imported via v.in.ascii. Just set your
region to n=10 e=10 s=-10 w=-10
Is there some way, how to create vertical boundaries or boundaries, which are
"one under the other"?
Thanks
Jáchym
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
(attachments)
square (312 Bytes)
This reguires 3D topology which is not supported. You can
import it as 'faces' ('F', closed polygons), but only few modules
supports faces. The faces are currently useful
only for visualisation in NVIZ.
Radim
On Sunday 24 October 2004 14:56, Jachym Cepicky wrote:
Hallo,
  133 +-----+ 233
  122 +-----+ 222
  111 +-----+ 211
  sideways:
position, so:
  123 +-----+ 223
  122 +-----+ 222
  111 +-----+ 211
  sideways:
  113 +-----+ 213
  122 +-----+ 222
  111 +-----+ 211
  sideways:
: 7)
your region to n=10 e=10 s=-10 w=-10
are "one under the other"?
Thanks
Jáchym
Thank You,
I realy need this only for NVIZ.
However
do I understand it right, that 2 faces can not have common boundary?
    Something like
    | F1 | F2 |
By me, it works only, when every face has it's own boundary
    | F1 || F2 |
Jáchym
Radim
> Hallo,
> 133 +-----+ 233
> 122 +-----+ 222
> 111 +-----+ 211
> sideways:
> position, so:
> 123 +-----+ 223
> 122 +-----+ 222
> 111 +-----+ 211
> sideways:
> 113 +-----+ 213
> 122 +-----+ 222
> 111 +-----+ 211
> sideways:
> : 7)
> Thanks
> Jáchym
Jachym Cepicky
Yes, faces are closed polygons, boundary is not shared.
Radim
On Monday 25 October 2004 08:33, Jachym Cepicky wrote:
Thank You,
However
    Something like
    | F1 | F2 |
    | F1 || F2 |
Jáchym
> Radim
> > Hallo,
> > squares are looking like this:
> > 133 +-----+ 233
> > 122 +-----+ 222
> > 111 +-----+ 211
> > sideways:
> > position, so:
> > 123 +-----+ 223
> > 122 +-----+ 222
> > 111 +-----+ 211
> > sideways:
> > 113 +-----+ 213
> > 122 +-----+ 222
> > 111 +-----+ 211
> > sideways:
> > boundaries
> > : 7)
> > problem.
> > set your region to n=10 e=10 s=-10 w=-10
> > which are "one under the other"?
> > Thanks
> > Jáchym
