Aside from simply setting a point of reference and drawing a static map based on a DEM, is there a way to generate a 3D map which I can use as some sort of fly-over? In other words, with a DEM and a 2D image overlaid on top, I'd like to generate a file that I can use in a 3D viewer (perhaps Quicktime or something similar) which enables me to zoom in and out and change my point of reference without going back to GRASS to redraw.
This can be done in NVIZ--including the animated flyover.
Michael
GRASS to redraw.
David
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
Do I have to use the NVIZ viewer separate from my own application, or is there a way to view the data with OpenGL?
David
Michael
GRASS to redraw.
David
USA
I think that you can save the animation files from NVIZ in a format you can
use in another app.
Michael
David
Michael
map
GRASS to redraw.
David
USA
USA
use in another app.
Michael
David
Michael
map
GRASS to redraw.
David
USA
USA
GRASS to redraw.
I'm not sure what you're asking for.
You can use p.vrml (if it still works) to export a DEM pair to a VRML
1.0 ElevationGrid node, which you can then view from any position and
direction.
Or you can use any of the r.out.* programs to dump the DEM to a raster
format which can be understood by a rendering package such as POVray,
and use that to render a fly-over animation.
Also, you can use NVIZ to render a fly-over as a series of images,
which can be converted to e.g. MPEG using a separate encoder.
I'm new to anything 3D (Grass or non-Grass), so I'm open to advice. Sounds like the VRML is what I was originally envisioning. I'll give that a shot.
David
GRASS to redraw.
direction.
[VRML solution]
(wasn't there a r.out.vrml once as well as r.out.pov? could of sworn)
see d.nviz for an easy solution for creating these. I think Bob
Covill's website had some examples. Tips for creating animations for
the web-wiki are on my todo list once I get back to home turf.
Also, for a while I've thought it would be not too hard to get GRASS
raster maps into TerraGear, the scenery generating end of the open
source FlightGear flight simulator. Currently it takes USGS DEMs, SRTM
DEMs, and shape files amongst other file formats for input. http://terragear.org http://flightgear.org
.. but I haven't spent any time trying this yet. I'd really like to
bring these two projects together. I think that is the most promising
long term solution for what you want.
I've also got a Matlab hack which runs a little flight sim through your
3d surface in a Matlab display window. A bit weird but it works. Export
your DEM into Matlab with r.out.mat.
luck,
Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
[VRML solution]
I suspect that you're thinking of p.vrml. I have no idea why it isn't
called r.out.vrml.
