On Sun, Jul 03, 2005 at 01:57:11PM -0700, Michael Barton wrote:
There was a discussion about this about a month ago after I tried r.random
and found that all the points clustered along the top edge of the region.
Apparently it is something to do with how the random function was/is
implemented. For a Mac, it makes the y dimension far too small. Glynn
explained the issue. What I don't remember is if it was fixed in the cvs or
not.
I don't think so. A cleanup is needed (volunteers?)
Michael
On 7/3/05 11:21 AM, "Markus Neteler" <neteler@itc.it> wrote:
> Michael,
> I don't have a Mac, so I don't know...
> Generally I would suggest to move the rand() etc code which
> is scattered around to aa central place.
> Markus
> On Sat, Jul 02, 2005 at 09:18:13PM -0700, Michael Barton wrote:
>> Markus,
>> Does the random point generator now work on Mac's too? It didn't work on
>> Mac's a month back.
>> Michael
>> On 7/1/05 8:23 AM, "Markus Neteler" <neteler@itc.it> wrote:
>>> Yes, it works. I have right now extended v.random to optional 3D support
>>> to easily generate test data:
>>> - launch GRASS with Spearfish60
>>> - run
>>> g.region rast=elevation.dem -p
>>> v.random -z out=rand3d n=25 zmin=1200 zmax=2500
>>> v.info rand3d
>>> nviz elevation.dem
>>> # load vector points in "Vector points" menu, "NEW" button
>>> # then select "3D Points", draw
>>> Works well...
>>> Markus
>>> On Fri, Jul 01, 2005 at 10:33:24AM +0200, benducke@compuserve.de wrote:
>>>> Yes, I did, but the results were no different
>>>> rom the Display on Surface option.
>>>> Is the "3D Points" option known to work?
>>>>> ----- Originalnachricht -----
>>>>> Von: Markus Neteler <neteler@itc.it>
>>>>> Datum: Freitag, 1. Juli 2005 8:54 am
>>>>> Betreff: [GRASSLIST:7400] Re: 3d point vectors in nviz
>>>>>> On Thu, Jun 30, 2005 at 03:32:16PM +0200, benducke@compuserve.de
>>>>>> wrote:> Has anyone successfully managed to get a 3D points cloud
>>>>>>> to display correctly in nviz?
>>>>>>> I checked 3D region settings and the structure of the
>>>>>>> vector file itself. The data and settings seem fine.
>>>>>>> I can display the zcoords with d.vect and it looks
>>>>>>> ok.
>>>>>>> However, when I load the map into nviz, I only get
>>>>>>> to see the top points of the vector map (i.e. I get
>>>>>>> to see as much as the top-down view by d.vect),
>>>>>>> the remaining points do not get displayed.
>>>>>>> I would very much appreciate any help!
>>>>>> Did you activate "3D Points" in the Vector points menu?
>>>>>> Markus
>> ____________________
>> C. Michael Barton, Professor of Anthropology
>> School of Human Evolution and Social Change
>> PO Box 872402
>> Arizona State University
>> Tempe, AZ 85287-2402
>> USA
>> Phone: 480-965-6262
>> Fax: 480-965-7671
>> www: <www.public.asu.edu/~cmbarton>
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
