[GRASS5] [5.7] v.out.ascii to stdout
5.7's v.out.ascii produces no output when output= isn't specified.
(i.e. -> stdout)
line 35 of grass51/vector/v.out.ascii/b2a.c
   if ( pnt && !(type & GV_POINT) ) continue;
That should that be ..!(type && GV_POINT) right?
I'd guess so, but the bitwise stuff isn't my forte.
thanks,
Hamish
(i.e. -> stdout)
That's correct, I think, did you get a wrong output?
Maybe better !(type & (GV_POINT|GV_CENTROID) ) ?
Radim
> (i.e. -> stdout)
Without the change I get no output:
G57: > v.out.ascii in=land
writing to stdout
G57: >
same for maps with only areas or maps with only lines.
Changing & to && I get:
G57: > v.out.ascii in=land | wc -l
writing to stdout
2016589.9107143|5433474.7978984
2009912.00812986|5447994.01089015
2008323.09308861|5442074.97924335
2022526.22078371|5439394.32499626
2010007.76416546|5445751.81902361
2020753.91103019|5438573.57601026
2021207.84465802|5440556.75323897
2013825.65294696|5451055.89008002
2017778.35756621|5452245.97672999
2017641.3474592|5451595.88459047
4750
Changing to "if ( pnt && !(type & (GV_POINT|GV_CENTROID) ) ) {"
I get:
writing to stdout
2017617.60219158|5435424.46544081|1
2011453.44388222|5448739.02879616|2
2009179.7786609|5442232.57413524|3
2022819.40801294|5438327.87323714|4
2009919.20095461|5445111.52844015|5
2020407.25907573|5438021.51196787|6
2021131.5452502|5440454.40233992|7
2013591.90459184|5450931.40066914|8
2017416.9871779|5452080.59517219|9
2017965.18476999|5451918.73312143|10
2308
G57: > v.build land
Building topology ...
4749 primitives registered
2307 areas built
2306 isles built
Topology was built.
Number of nodes : 4748
Number of primitives: 4749
Number of points : 0
Number of lines : 0
Number of boundaries: 2442
Number of centroids : 2307
Number of areas : 2307
Number of isles : 2306
not sure which is "better" or expected output. Usually I'd think nodes
were more useful to have exact positions for than centroids..
Hamish
writing to stdout
G57: >
Correct, no points.
writing to stdout
4750
Wrong, 'type && GV_POINT' is always true, writes out first point of lines.
I get:
writing to stdout
2308
OK, writes centroids (in this case).
This I don't understand.
Radim
On Wed, 26 May 2004 15:58:44 +0200
> writing to stdout
> G57: >
Correct, no points.
Perhaps we should add a "WARNING: no point data" message in that case?
> writing to stdout
> 4750
lines.
> I get:
> writing to stdout
> 2308
> nodes were more useful to have exact positions for than centroids..
Perhaps we should think about adding a type=point,area,centroid,line,etc
option to v.out.ascii?
This isn't something I need right now, but it might be useful to
someone..
Hamish
