OK... what stupid thing am I forgetting here. I'm trying to update my 53 and 57 sources via cvs. I did (I think this has always worked before):
cd /where/your/grass530/lives/
cvs update -dP
configure
make
make install
cd /where/your/grass57/lives/
make mixclean
cvs update -dP
make mix
configure ...
make
However, I'm getting the following on the final make for 57:
de ]; then mkdir /Users/kirkw/grass5_dev/grass57_cvs/dist.powerpc-apple-darwin7.2.0/include; fi
if [ ! -d /Users/kirkw/grass5_dev/grass57_cvs/dist.powerpc-apple-darwin7.2.0/include/vect ]; then mkdir /Users/kirkw/grass5_dev/grass57_cvs/dist.powerpc-apple-darwin7.2.0/include/vect; fi
cp ../include/*.h /Users/kirkw/grass5_dev/grass57_cvs/dist.powerpc-apple-darwin7.2.0/include/
cp: ../include/CC.h: No such file or directory
cp: ../include/vbuildlib.h: No such file or directory
cp: ../include/vask.h: No such file or directory
cp: ../include/transform.h: No such file or directory
cp: ../include/std_incs.h: No such file or directory
cp: ../include/sitelib.h: No such file or directory
cp: ../include/site.h: No such file or directory
cp: ../include/shhopt.h: No such file or directory
cp: ../include/segment.h: No such file or directory
cp: ../include/search.h: No such file or directory
cp: ../include/rowio.h: No such file or directory
cp: ../include/region_bm.h: No such file or directory
cp: ../include/readsites.h: No such file or directory
cp: ../include/pbmplus.h: No such file or directory
cp: ../include/patterns.h: No such file or directory
cp: ../include/ortholib.h: No such file or directory
cp: ../include/monitors.h: No such file or directory
cp: ../include/lock.h: No such file or directory
cp: ../include/linkm.h: No such file or directory
cp: ../include/lapack.h: No such file or directory
cp: ../include/label_bm.h: No such file or directory
cp: ../include/la.h: No such file or directory
cp: ../include/imagery.h: No such file or directory
cp: ../include/imagedefs.h: No such file or directory
cp: ../include/icon_bm.h: No such file or directory
cp: ../include/icon.h: No such file or directory
cp: ../include/ibtree.h: No such file or directory
cp: ../include/help.h: No such file or directory
cp: ../include/graph.h: No such file or directory
cp: ../include/gproj_api.h: No such file or directory
cp: ../include/gmath.h: No such file or directory
cp: ../include/glocale.h: No such file or directory
cp: ../include/geom.h: No such file or directory
cp: ../include/geo.h: No such file or directory
cp: ../include/edit.h: No such file or directory
cp: ../include/dlg_bm.h: No such file or directory
cp: ../include/dlg.h: No such file or directory
cp: ../include/display.h: No such file or directory
cp: ../include/dig_atts.h: No such file or directory
cp: ../include/devlib.h: No such file or directory
cp: ../include/datetime.h: No such file or directory
cp: ../include/colors.h: No such file or directory
cp: ../include/btree.h: No such file or directory
cp: ../include/blas.h: No such file or directory
cp: ../include/bitmap.h: No such file or directory
cp: ../include/bdlg_bm.h: No such file or directory
cp: ../include/V_.h: No such file or directory
cp: ../include/Paintlib.h: No such file or directory
cp: ../include/P_datetime.h: No such file or directory
cp: ../include/G3d.h: No such file or directory
cp: ../include/D.h: No such file or directory
make[1]: *** [headers] Error 1
make: *** [default] Error 1
Kirk R. Wythers tel: 612.625.2261
Dept. of Forest Resources fax: 612.625.5212
University of Minnesota email: kwythers@umn.edu
before):
cvs update -dP
configure
make
make install
make mixclean
cvs update -dP
make mix
configure ...
make
Are you sure that you have set:
configure --with-grass50=/where/your/grass530/lives [...]
Ya... I think so
#compilation of GRASS 5.7 on Mac OSX with shared libraries
./configure --with-grass50=/Users/kirkw/grass5_dev/grass53_cvs \
--enable-shared \
--enable-64bit \
--with-postgres-includes=/sw/include/postgresql \
--with-postgres-libs=/sw/lib/postgresql \
--with-gdal=/usr/local/bin/gdal-config \
--with-includes="/usr/X11R6/include /sw/include" \
--with-libs="/usr/X11R6/lib /sw/lib" \
--with-freetype \
--with-freetype-includes=/usr/X11R6/include/freetype2 \
--with-motif \
--with-glw \
--with-readline \
--with-proj \
--with-cxx
Don't you do the configure BEFORE the make mix? This is how I've always done it. No problems with the 3/13 cvs snapshot this weekend for me on MOSX.
cvs update -dP
configure
make
make install
make mixclean
cvs update -dP
make mix
configure ...
make
William Kyngesburye <kyngchaos@charter.net>
http://webpages.charter.net/kyngchaos/
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
That's how I've done it before as well. And tha't how I did this time too (on my first try). When that yielded the error, I tried the order that was spelled out in the 57 INSTALL file. You know... when something doesn't work, THEN read the INSTALL file.
Kirk
And then, if you find errors in the INSTALL file, please report
Kirk
>for me on MOSX.
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
