Glynn,
While your explanation makes sense, it doesn't seem to exactly match what I am seeing--at least not obviously.
1. I open grass and a bunch of windows open up--saved window geometry from the last time I used grass.
2. I select the option to automatically resize all the windows, and they shrink to the correct initial size.
3. I save configuration and quit grass (I also check the save configuration box in the quick dialog)
4. I reopen grass and the same windows reopen, but all have grown about 23 pixels in the y dimension. They grow down, not up. They do not grow in the x dimension. This only happens for menus & dialogs, not for monitor windows.
5. If I continue this without doing an automatic resize, they all grow another 23 pixels each time I reopen grass. They at least grow to the edges of the screen if I let them, and perhaps can grow off the screen. I can send you screen shots, but don't want to send something big to the list.
I can's say that my Mac WM is not somehow resizing these windows, but somehow the saved geometry is augmented by about 23 pixels downwards in the y-dimension only and for tcltk menus and dialogs only, every time I quit or open (I don't know which end this happens on). This seems odd.
Michael
On Sunday, November 23, 2003, at 12:04 AM, Glynn Clements wrote:
Michael Barton wrote:
This is probably a trivial question, but is something that can get
annoying. It seems that every time I open the grass tcltk interface all
the windows get larger vertically by some amount. If I don't do a
config>module windows>automatic size for all active windows
just about every time I run grass, the tcltk module windows grow right
off the screen. It doesn't matter if I try to save config. In the next
session, they begin to grow again.
It seems like there is some kind of window size variable that is
automatically incrementing in the y-dimension every time grass is
initialized. Am I the only person with this strange behavior? Is there
some way to stop the growing windows in one of the tcltk files?
I don't know if you're the only person, but I can't reproduce it.
However, I can see a plausible explanation. tcltkgrass records the
geometry of each module window. When it creates the window, it uses
the stored geometry (if present). When it receives a Configure event
(indicating that the window has been created or resized), it updates
the stored geometry.
If the WM makes the window larger than requested, the enlarged size
will be stored and used for the next window, which presumably will be
enlarged even more, and so on. I'm not sure that there's any way that
tcltkgrass can avoid this (other than by simply not attempting to
store the geometry); if a window is enlarged, it can't tell whether
this occurred due to user interaction or due to the WM's automatic
behaviour.
In any case, there doesn't appear to be an option to disable storing
the geometry. To do that, you would need to remove the following code
fragments from tcltkgrass/main/gui.tcl:
bind $path <Configure> {
if [regexp {^\.([^.]+)$} %W buffer array] {
set ${array}(window_geometry) [wm geometry %W]
and/or:
bind $name <Configure> {
if [regexp {^\.([^.]+).print$} %W buffer array] {
set ${array}(result_geometry) [wm geometry %W]
[Search for <Configure> in gui.tcl.]
Note: window_geometry corresponds to the dialog into which the options
are entered, while result_geometry corresponds to the text window
which displays the results.
____________________
C. Michael Barton, Professor
Department of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
