[GRASS5] ANN: GRASS display with projection
Dear developers,
recently I received code from Beverly Wallace which allows to
display raster/vector/sites map projected in a GRASS monitor.
See details below, the C code is available in:
http://grass.itc.it/outgoing/
-> display_viewproj_src*
I tried it on Linux, it works as expected. Congrats to Beverly.
The limitation is that it currently uses an older version of
PROJ4 which is included and locally compiled.
PS: Here the announcement:
On Mon, Feb 03, 2003 at 04:57:59PM -0800, Wallace, Beverly T wrote:
Markus,
I have attached a gzipped tar file of the viewproj code. It includes a
PROJ library (named differently from the GRASS version) and a proj.4 data
directory that are needed by viewproj.
To make it, run gmake5 from the LM directory. I tested it using GRASS
5.0.0 on a Sun with Solaris 8.
Documentation is in viewproj/README. I will write html documentation soon.
To demonstrate viewproj, if you have a lat/lon database with nations and
coastlines data, then start a monitor and run the demo.viewproj.sh script.
Please let me know if you have any questions or comments.
<<LM.tar.gz>>
Bev Wallace
Lockheed Martin, Sunnyvale, CA, USA
beverly.t.wallace@lmco.com
