[GRASS5] ANN: GRASS on iPAQ/Linux available
GRASS on handhelds
Jan Stankovic and me may announce that (baby)GRASS is
running now on iPAQ/Linux:
http://grass.itc.it/grasshandheld.html
With kind help of Nick Duffek <nick.duffek@compaq.com> we
got binaries compiled on ipaq3.handhelds.org (this are
new machines, in parallel to the Skiff cluster).
The code (not stripped) needs 2.4MB and currently includes:
d.erase d.measure d.mon d.pan d.rast d.sites d.vect d.what.rast d.what.sites
d.what.vect d.zoom g.copy g.gisenv g.list g.region g.remove g.rename
r.in.ascii s.in.ascii
XDRIVER
More modules can be easily added in
handheld/babyGRASS_packagingsrc.sh
For compilation (GRASS shared libs) there is
handheld/babyGRASS_compile.sh
Notes:
- The flag to gcc "-gstabs" made it binary compliant (I don't know why
  but it works).
- the src/libes/dig_atts/ compiles now without problems, subsequently
  all vector modules are compilable
- we have to look again at d.zoom to get the 1-button mode working
  (it runs on iX86/Linux, but not on iPAQ)
- the gcc on ipaq3.handhelds.org is very sensitive to warnings,
  even if indicated as warning during compile time, linking will fail.
  Means: ipaq3.handhelds.org is a platform to find such warnings...
- we still do not get "debugging symbols" present, but anyway - GRASS
  is working now
Kudos to Glynn Clements for his efforts on shared libraries.
Enjoy
I'll follow that up by announcing that I've packaged up these same
binaries and contributed them to the Familiar distribution.
This means, that iPAQ users running Familiar can now simply do:
  ipkg install grass
to download and install grass. This will currently work as long as the
user is pointing at Familiar's "unstable" feed[*]. By the time
Familiar 0.5.3 is released, grass will be available as part of the
standard distribution.
If someone would like to install the package without pointing at the
unstable feed, then the following command will also work:
  ipkg install http://familiar.handhelds.org/familiar/feeds/unstable/packages/armv4l/grass_5.0.0-20020507-1_arm.ipk
A few notes on the package I made:
  o It installs its binary as /usr/bin/grass5
  o All other files are in /usr/share/grass/,
  (eg. /usr/share/grass/bin, /usr/share/grass/etc, etc.) This
  layout matches standard (FHS) practice and is cleaner than
  installing directories such as
  dist.armv4l-unknown-linux-gnu. Perhaps I should change it to
  /usr/share/grass5 though?
  o There is a bug in ipkg preventing it from installing
  packages with hard links correctly. So I expanded all the
  files in /usr/share/grass/bin into separate files. This bloats
  the package a bit, but I also stripped all the libraries which
  compensates almost exactly. (I plan to fix the bug in ipkg
  soon *blush*).
Things I would like to do next include making all of GRASS available
in separate packages, creating a better mechanism for doing partial
builds of grass, and adding package creation targets to the GRASS
makefiles.
> Notes:
I'll be looking into this right away.
> is working now
Markus, you asked for this. Your script passes "-s" to ld which
removes the debugging symbols, (although strip can shrink the
libraries you generated a bit more).
-Carl
[*] A user can point to Familiar's unstable feed by adding the
following line to /etc/ipkg.conf:
  src familiar-unstable http://familiar.handhelds.org/familiar/feeds/unstable/pack ages/armv4l
Carl Worth
USC Information Sciences Institute cworth@east.isi.edu
3811 N. Fairfax Dr. #200, Arlington VA 22203 703-812-3725
  ipkg install grass
Congrats, Carl!
  soon *blush*).
makefiles.
Yes - my scripts are pretty rough. We need a more conventient method.
Carl, may I ask you to add your notes to
web/grasshandheld.html
cvs -z3 co web
will get the pages to you.
> Notes:
Perfect.
> is working now
I am not sure - I had disabled LDFLAGS="". In the head file is written
src/CMD/head/head
CC = gcc
FC =
LEX = flex
COMPILE_FLAGS = -g -gstabs
LINK_FLAGS =
There is no "-s", also not in the script (see latest CVS version):
CFLAGS="-g -gstabs" LDFLAGS="" ./configure --prefix=...
Still there are no debugging symbols.
cd dist.armv4l-unknown-linux-gnu/etc/bin/cmd
gdb d.vect
GNU gdb 2002-04-01-cvs
This GDB was configured as "arm-linux"...(no debugging symbols found)...
(gdb)
There must be another trick.
/usr/share is supposed to be for files which are shareable across
architectures, i.e. not executables or libraries. I suggest using
/opt.
Basically, the GISBASE concept (i.e. all of GRASS residing within a
single directory) is at odds with the conventional Unix directory
structure (files grouped by type rather than by package) of FHS.
  soon *blush*).
Rather than making lots of copies of front.end, either use symlinks,
or generate the links with an installation script.
/opt.
I agree as /opt also fits FHS and suites GRASS better.
> > /opt.
Good points. I'll switch to /opt/grass5 then.
Now, to start looking at why d.zoom doesn't work on my iPAQ...
-Carl
Carl Worth
On Tuesday 07 May 2002 05:39 pm, Carl Worth wrote:
> Notes:
Fixed.
Radim
> > Notes:
Fixed.
Also
http://grass.itc.it/grass5/binary/ipaq_linux/iPAQ_linuxbins.tar.gz
is updated accordingly.
Just another follow-up: With a few trivial hacks to gui.tcl
we got "tcltkgrass" running on the iPAQ. Of course it is not
really convenient, but just an indicator that a better GUI is
needed (maybe an upcoming handhelds GUI can inspire the desktop
version of a GUI).
