this bug's URL: http://intevation.de/rt/webrt?serial_num=1038
Subject: Tempfile cleanup problem revisited: G_tempfile()
grass obtained from: CVS
GRASS Version: latest CVS
some of you may remember the thread about the GRASS tempfile problem:
http://grass.itc.it/pipermail/grass5/2002-April/002598.html
I have revisited the problem and done a draft check where G_tempfile() function
is used but the temp file not deleted later (using unlink()). This leads to left-over
files if GRASS is not left with "exit" (but simply the GRASS shell-window clicked
away) since $ETC/clean_temp won't be run in this case. In our networked GRASS
database I found 1GB leftover files.
My quick-and-dirty test has delivered:
find . -type f -name '*.c' -exec grep -l G_tempfile {} \;
find . -type f -name '*.c' -exec grep -l unlink {} \;
Diff'ed list of potential modules which call G_tempfile() but do not
use the unlink() function to delete the tempfile(s) later:
- example: r.drain
./src/mapdev/v.extract/inter/main.c
./src/mapdev/v.digit/digmain.c
./src/mapdev/v.digit/main.c
./src/mapdev/v.in.arc/main_cmd.c
./src/mapdev/v.in.arc/main_inter.c
./src/mapdev/v.in.mif/write_lines.c
./src/mapdev/v.in.shape/test/arctest1.c
./src/mapdev/v.out.arc/main.c
./src/mapdev/v.out.shape/main.c
./src/imagery/i.class/main.c
./src/imagery/i.pca/cmd/main.c
./src/imagery/i.points3/inter/list_group.c
./src/display/d.barscale/cmd/mouse.c
./src/display/d.display/histo.c
./src/display/d.label/cmd/label.c
./src/display/d.labels/do_label.c
./src/display/d.labels/proc_old.c
./src/display/d.profile/Range.c
./src/display/d.rast.edit/mk_tmp_file.c
./src/display/d.rast.edit/main.c
./src/display/d.rast.edit/mk_new_layer.c
./src/display/d.scale/cmd/draw_scale.c
./src/display/d.site.labels/do_labels.c
./src/display/d.text/cmd/main.c
./src/display/d.vect.labels/do_labels.c
./src/display/devices/CELL/Graph_Set.c
./src/display/devices/CELL/Graph_Clse.c
./src/display/devices/CELL/Panel.c
./src/display/devices/PNGdriver/Panel.c
./src/display/devices/XDRIVER/XDRIVER24/Panel.c
./src/display/devices/lib/connect_sock.c
./src/display/d.vect.area/d.vect.area.c
./src/display/d.vect.line/d.vect.line.c
./src/libes/display/popup.c
./src/general/init/clean_temp.c
./src/libes/g3d/g3dopen.c
./src/libes/g3d/g3dclose.c
./src/libes/g3d/g3drange.c
./src/libes/gis/closecell.c
./src/libes/gis/opencell.c
./src/libes/gis/put_title.c
./src/libes/gis/remove.c
./src/libes/lock/lock.c
./src/libes/lock/unlock.c
./src/libes/raster/Panel.c
./src/libes/raster/io.c
./src/libes/raster/new_io.c
./src/libes/vect32/Vlib/open1.c
./src/libes/vect32/bin_digit/bin_digit.c
./src/libes/vect32_64/Vlib/open1.c
./src/misc/m.dem.extract/getgrid.c
./src/misc/m.dem.extract/main.c
./src/misc/m.dem.extract/usgs_buf.c
./src/misc/m.dem.extract/usgs_num.c
./src/misc/m.svfit/hgnio.c
./src/misc/m.svfit/pltline.c
./src/paint/Programs/p.icons/edit.c
./src/misc/m.svfit/save.c
./src/paint/Drivers/shinko635/finish.c
./src/paint/Drivers/versatec/driver/finish.c
./src/paint/Drivers/versatec/driver/write.c
./src/paint/Interface/driverlib/interface.c
./src/paint/Programs/p.map/cmd/comment.c
./src/paint/Programs/p.map/cmd/label.c
./src/paint/Programs/p.map/cmd/main.c
./src/paint/Programs/p.map/cmd/plfile.c
./src/paint/Programs/p.map/cmd/session.c
./src/paint/Programs/p.map.new/cmd/barscale.c
./src/paint/Programs/p.map.new/cmd/colrtable.c
./src/paint/Programs/p.map.new/cmd/comment.c
./src/paint/Programs/p.map.new/cmd/do_barscale.c
./src/paint/Programs/p.map.new/cmd/do_legend.c
./src/paint/Programs/p.map.new/cmd/do_legendfin.c
./src/paint/Programs/p.map.new/cmd/label.c
./src/paint/Programs/p.map.new/cmd/legendtable.c
./src/paint/Programs/p.map.new/cmd/linefile.c
./src/paint/Programs/p.map.new/cmd/do_labels.c
./src/paint/Programs/p.map.new/cmd/main.c
./src/paint/Programs/p.map.new/cmd/plfile.c
./src/paint/Programs/p.map.new/cmd/pre_legend.c
./src/paint/Programs/p.map.new/cmd/regionfile.c
./src/paint/Programs/p.map.new/cmd/session.c
./src/ps.map/ps.map/cmd/comment.c
./src/ps.map/ps.map/cmd/label.c
./src/ps.map/ps.map/cmd/do_masking.c
./src/ps.map/ps.map/cmd/plfile.c
./src/ps.map/ps.map/cmd/session.c
./src/raster/r.agnps50/src_agnps_input_1/cell_num_id.c
./src/raster/r.agnps50/src_agnps_input_1/misc_routines.c
./src/raster/r.agnps50/src_agnps_input_2a/cell_num_id.c
./src/raster/r.agnps50/src_agnps_input_2a/misc_routines.c
./src/raster/r.binfer/reclass.c
./src/raster/r.drain/main.c
./src/raster/r.fill.dir/main.c
./src/raster/r.flow/io.13.c
./src/raster/r.mapcalc/mapcalc/main.c
./src/raster/r.out.mpeg/main.c
./src/raster/r.null/null.c
./src/raster/r.out.gridatb/check_ready.c
./src/raster/r.report/cmd/parse.c
./src/raster/r.support/inter/support.c
./src/raster/r.surf.contour/cmd/bseg_close.c
./src/raster/r.surf.contour/cmd/cseg_close.c
./src/raster/r.thin/cmd/thin_lines.c
./src/raster/r.topmodel/check_ready.c
./src/raster/r.watershed/seg/bseg_close.c
./src/raster/r.watershed/seg/cseg_close.c
./src/raster/r.watershed/seg/dseg_close.c
./src/raster/r.watershed/seg/seg_close.c
./src/raster/r.watershed/seg/sseg_close.c
./src/sites/s.sv/plthgpt.c
./src/sites/s.sv/save.c
./src/sites/s.probplt/save.c
./src/sites/s.to.rast/main.c
./src/sites/s.to.vect/cmd/main.c
./src/sites/s.to.rast/write_cell.c
./unused/display/d.vect.zoom/label.c
./unused/display/d.vect.zoom/what.c
./src.contrib/CERL/raster/r.water.fea/src/inter/shell.c
./unused/sites/s.menu/site_reports/run_report.c
./src.contrib/GMSL/g3d/src3d/raster/r3.mapcalc/mapcalc/main.c
./src.contrib/GMSL/xganim/main.c
./src.contrib/SCS/imp_exp/dig_dlg/v.exp_dlg.c
./src.contrib/SCS/imp_exp/dig_dlg/v.export_dlg.c
./src.contrib/SCS/imp_exp/dlg_dig/dlgcat.c
./src.contrib/SCS/imp_exp/gef_dig/imp_main.c
./src.contrib/SCS/imp_exp/tig_dig/imp_main.c
./src.contrib/SCS/mapdev/dlg_to_bdlg.scs/a_b_dlg.c
./src.contrib/SCS/misc/dotmaps/v.scale.random/main.c
./src.contrib/SCS/paint/Drivers/color.ps/text.c
./src.contrib/SCS/paint/Drivers/grey.ps/text.c
./src.contrib/SCS/paint/Drivers/grey.ps.n/text.c
./src.contrib/SCS/paint/Programs/color.map/cmd/comment.c
./src.contrib/SCS/paint/Programs/color.map/cmd/label.c
./src.contrib/GMSL/g3d/src3d/sites/s.vol.rst/user4.c
./src.contrib/SCS/paint/Drivers/driverlib/interface.c
./src.contrib/SCS/paint/Interface/driverlib/interface.c
./src.contrib/SCS/paint/Programs/color.map/cmd/main.c
./src.contrib/SCS/paint/Programs/color.map/cmd/plfile.c
./src.contrib/SCS/paint/Programs/color.map/cmd/session.c
./src.contrib/SCS/paint/Programs/grey.map/cmd/comment.c
./src.contrib/SCS/paint/Programs/grey.map/cmd/label.c
./src.contrib/SCS/paint/Programs/grey.map/cmd/main.c
./src.contrib/SCS/paint/Programs/grey.map/cmd/plfile.c
./src.contrib/SCS/paint/Programs/grey.map/cmd/session.c
./src.contrib/SCS/paint/Programs/newp.map/cmd/barscale.c
./src.contrib/SCS/paint/Programs/newp.map/cmd/colrtable.c
./src.contrib/SCS/paint/Programs/newp.map/cmd/comment.c
./src.contrib/SCS/paint/Programs/newp.map/cmd/do_barscale.c
./src.contrib/SCS/paint/Programs/newp.map/cmd/do_legend.c
./src.contrib/SCS/paint/Programs/newp.map/cmd/label.c
./src.contrib/SCS/paint/Programs/newp.map/cmd/legendtable.c
./src.contrib/SCS/paint/Programs/newp.map/cmd/linefile.c
./src.contrib/SCS/paint/Programs/newp.map/cmd/main.c
./src.contrib/SCS/paint/Programs/newp.map/cmd/plfile.c
./src.contrib/SCS/paint/Programs/newp.map/cmd/pre_legend.c
./src.contrib/SCS/paint/Programs/newp.map/cmd/regionfile.c
./src.contrib/SCS/paint/Programs/newp.map/cmd/session.c
./src.contrib/SCS/paint/Programs/ps.map/session.c
./src.contrib/SCS/paint/Programs/ps.map/main.c
./src.contrib/SCS/raster/r.in.miads/cmd/proces.c
./src.contrib/SCS/raster/r.reclass.scs/inter/main.c
./src.contrib/SCS/sites/s.dotmap.new/inter/main.c
./src.contrib/SCS/sites/s.dotmap.new/inter/sfactor.c
./src.contrib/SCS/vector/v.dump/cmd/edit_head.c
./src.contrib/SCS/vector/v.mk_stats/do_stats.c
./src.contrib/SCS/vector/v.proj/cmd/main.c
./src.contrib/SDTS/mapdev/v.in.sdts/wr_attrs.c
./src.garden/answers/src.answers/raster/r.direct/cmd/direct.c
(slightly cleaned up list)
These modules have to be checked if the G_tempfile is properly
deleted on G_fatal_error() or successful module termination.
