this bug's URL: http://intevation.de/rt/webrt?serial_num=1045
Subject: New r.mapcalc bug in G5pre4
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: 5.0pre4
The new version of r.mapcalc as shipped with the 5pre4sources doesn't cope with equations like '1900.54 = if (("1900.32" > 8.0),"1900.32",0' or
'x = (1.0 + (0.3 * "y"))'
The problem seems to be the handling of the ""-terms.
Remigrating back to 5pre3 can be used as a workaround.
Peter Löwe
This looks like a similar problem that we have with the new r.mapcalc - in our case the problem was
spaces. It appears that the new r.mapcalc has some changes in how it interprets the expression which
is breaking old scripts - I think that it should be fixed (or reverted to pre3 version?- what else is different compared to pre3?
Helena
Peter Löwe
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
r.mapcalc - in our case the problem was spaces. It appears that
expression which is breaking old scripts - I think that it should
compared to pre3?
First we should hear some reasons for the change in behaviour.
Sometimes it is better to fix behaviour if there are good reasons for this.
Thanks for the report. Fixed in CVS.
- in our case the problem was spaces. It appears that the new
I can only fix bugs which are reported.
The only intentional changes from the original r.mapcalc are that the
type inference is more conservative, and that floating-point values
are no longer acceptable where a boolean value is expected.
Any other difference is probably a bug, and will be fixed if
reported.
pre3?
The current version is a complete re-write.
