[GRASS5] bug 1177: patch <- Radim?
There is a patch in the bug tracker which supposely
fixes wish 1177. Radim, you are most proficient with the vector format.
Would it be possible for you to evaluate the patch and commit
it onto HEAD if you think it is worth it?
Unfortunately it seems to me that it is not quite correct because
original areas are restored only by
    map->Area[area1].alive = 1;
which is not sufficient because old line must be deleted from area
and new lines added.
It doesn't crash because of
    if (!LINE_ALIVE (&(map->Line[line])))
         continue;
in _area_display().
Radim
