this bug's URL: http://intevation.de/rt/webrt?serial_num=1566
Subject: vector data select by attribute
GRASS Version: 5.0.0 (Aug 2002)
Improved support for selecting vector data by attribute (eg: 200m contours from a vector map of contour data) and to select from multiple maps to create a new map (or ideally to create a virtual map with pointers to the data, which may optionally be saved as a new map).
I'm not sure if the 5.1 data management in PostGreSQL/PostGIS will permit this through the use of db views, if GRASS 5.1 can access such views as maps. If so, then the wish is coming true
Brent Wood
Brent Wood
Standard way to do this in 5.1 (format and db driver independent) is:
v.extract where=
v.patch
It is true that you can use views, but it is not intended for
normal usage.
Radim
