this bug's URL: http://intevation.de/rt/webrt?serial_num=1789
Subject: r.sun: target mask / memory usage
I just tried the new improvements to r.sun, they work great!
- target mask: would it be feasible to add a target mask? I only need
the sun data for a small area, but I do need to take into account the
surrounding mountains. Right now the mask blanks the elevation data as
well as the results. Seems wasteful to calculate answers for the entire
mountain range when all I need is such a small area in a valley.
(I realize this may pollute the reflection numbers)
- memory usage: can anything be done to keep this under control? it
chews through my gigabyte of memory pretty quickly.. I suppose if the
above target mask is implemented, this would not be such a issue?
thanks,
Hamish
