[GRASS5] [bug #239] (grass) d.display doesn't switch to full screen on exit
this bug's URL: http://intevation.de/rt/webrt?serial_num=239
Subject: d.display doesn't switch to full screen on exit
d.display doesn't switch to full screen on exit, one of the
windows remains the active frame. User would have to use
d.frame -e
to clean.
Suggestion: d.display should draw a "full_screen" frame first,
then the smaller windows. On exit the "full_screen" should
be selected (as d.frame -e erases the monitor contents).
Should be fixed to prevent newbie's confusion.
subject 'unsubscribe grass5'
