[GRASS5] [bug #2597] (grass) Some binary files not cleaned
this bug's URL: http://intevation.de/rt/webrt?serial_num=2597
Subject: Some binary files not cleaned
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: 5.7.0
While trying to package grass for Debian I get the following errors. Basically this means these files are not removed by 'make distclean'.
pkg-source: cannot represent change to lib/proj/nad2bin: binary file contents changed
dpkg-source: cannot represent change to tools/timer/main.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/ply_t_bmif.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/yadjust.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/bmf_to_cll.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/save_area.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/wrte_recrd.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/do_dots.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/find_area.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/do_line.o: binary file contents changed
Steve Halasz
nad2bin is no longer built.
Both of these are due to similar Makefile bugs. I.e. the default rule
changes to a subdirectory then builds something, but there isn't a
matching "clean" rule (the default "clean" rule only deletes object
files in the current directory).
I'll fix these specific cases, but ultimately there needs to be some
changes to the build system. Every directory with subdirectories
should define SUBDIRS, and the default clean rule should recurse into
those subdirectories.
