[GRASS5] [bug #2598] (grass) compilation bug
this bug's URL: http://intevation.de/rt/webrt?serial_num=2598
Subject: compilation bug
grass obtained from: Trento Italy site
GRASS Version: 5.7
In trying to compile grass57 from sources, it complains of not finding
gdal-config:
checking for gdal-config... no
configure: error: *** couldn't find gdal-config
Gdal is not listed as a pre-requisite But I compiled and installed it just in
case, but the configure script of GRASS 5.7 kept complaining about it.
Flavio C. Coelho
GRASS Version: 5.7
gdal-config:
If the gdal-config script isn't in the path, then you have to use
e.g. --with-gdal=/usr/local/bin/gdal-config.
