[GRASS5] [bug #2656] (grass) v.out.ogr fails to write negative cat values
this bug's URL: http://intevation.de/rt/webrt?serial_num=2656
Subject: v.out.ogr fails to write negative cat values
Platform: Mac OSX
grass obtained from: Trento Italy site
GRASS Version: 5.7cvs20041009
When exporting a vector map with no attribute table, just cats, and the cats contain some negative
values, those negative values don't get exported. The feature is still exported, just with no cat value.
GRASS says 'WARNING: nn features without category written' on all formats. In a shapefile, the values
in the dbf are a string of asterisks '***********'. In a csv file it's just empty. In a MapInfo dat file, I
can't tell for sure (just poking around with a hex editor), but it looks like they are either zero or null.
Example: lines generated from r.contour get no attribute table, with the elevations (rounded to
integers) in the category, and lines that are below sea level (or otherwise negative elevation) get
negative categories.
v.out.ascii works fine and exports negative cat values.
Cat values should never be negative. r.contour should
be modified to create a table.
Radim
Platform: Mac OSX
cats contain some negative values, those negative values don't get
exported. The feature is still exported, just with no cat value. GRASS
shapefile, the values in the dbf are a string of asterisks '***********'.
In a csv file it's just empty. In a MapInfo dat file, I can't tell for
elevations (rounded to integers) in the category, and lines that are below
sea level (or otherwise negative elevation) get negative categories.
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Ah. Should I refile this as a bug for r.contour?
Radim
Platform: Mac OSX
grass5 mailing list
grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
William Kyngesburye <kyngchaos@charter.net>
http://webpages.charter.net/kyngchaos/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
Yes.
Radim
> Radim
>> Platform: Mac OSX
>> the
>> GRASS
>> In a
>> for
>> are
>> the
>> below
>> Tracker
>> _______________________________________________
>> grass5 mailing list
>> grass5@grass.itc.it
> grass5 mailing list
> grass5@grass.itc.it
robot?
answer...
grass5 mailing list
grass5@grass.itc.it
