this bug's URL: http://intevation.de/rt/webrt?serial_num=3096
Subject: ps.map: Scale is all screwed up in Lat/Lon
grass 6.1-cvs mar 2005
When making a lat/lon map with ps.map, the scale is all messed up.
a map covering 3x4 degrees on an A4 page reports a scale of "1:16".
trying to adjust with the 'scale' ps.map command does nothing.
You have to size the map with maploc and page border size, but that doesn't
work very well.
also I think there might be a problem with the bounding box if you use the -r
rotate flag for a landscape page layout. gv and gnome-gv cut off the page at
about the portait page width if you tell it to display in landscape mode.
(not LL specific)
Hamish
