this bug's URL: http://intevation.de/rt/webrt?serial_num=3112
Subject: bug in r.watershed
Platform: other
grass obtained from: Mirror of Trento site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.4
I tried to use r.watershed with the spearfish data loaded on the website. I have created the different maps needed (depression,amount of overland flow, terrain blocking overland surface flow) and define the values (maximum size, maximum length). The r.watershed command start but never stop. It is still written :
Running: /usr/local/grass54/etc/water/ram el="elevation.dem" de="essaidepression" ov="essaiaccumulationflux" r="50" ob="essaiflowdirection" t=1000 ms=150 ac="essainbcells" se="essaistreamsegment" di="essairesult" 98%
and stay at 98 %
Could il be a Mandrake 10.1 problem ? Or just a mistake in the data compilation ?
Thanks
Pierre-Antoine
