this bug's URL: http://intevation.de/rt/webrt?serial_num=3117
Subject: r.out.pov fails when called out of d.m
Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: GRASS 6.1.cvs (2005)
r.out.pov map=alt_surf4 tga=/gd/test.tga hftype=1 causes the attached error
message.
When called from the command line, the file becomes written.
too many nested evaluations (infinite loop?)
(procedure "GlobalVar::exists" line 1)
invoked from within
"GlobalVar::exists $_widget($path,var)"
(procedure "ProgressBar::_modify" line 4)
invoked from within
"ProgressBar::_modify .dialog0.progress"
("eval" body line 1)
invoked from within
"eval ProgressBar::$cmd .dialog0.progress $args"
(procedure ".dialog0.progress" line 1)
invoked from within
"$opt($dlg,progress) _modify"
(procedure "progress" line 7)
invoked from within
"progress $dlg $val"
invoked from within
"if [eof $fh] {
close $fh
} else {
set str [gets $fh]
append str "\n"
if { [fblocked $fh] } { set str [read $fh] }
while {[set idx [string f..."
(procedure "prnout" line 5)
invoked from within
"prnout 1 file7"
A hint (I hope) for developers.
This bug looks exactly like http://intevation.de/rt/webrt?serial_num=2937
where v.in.ogr fails in GUI mode.
Maciek
----- Original Message ----- From: "Request Tracker" <grass-bugs@intevation.de>
To: <grass5@grass.itc.it>
Sent: Friday, March 25, 2005 3:42 PM
Subject: [GRASS5] [bug #3117] (grass) r.out.pov fails when called out of d.m
error
message.
invoked from within
invoked from within
invoked from within
invoked from within
invoked from within
invoked from within
"if [eof $fh] {
close $fh
} else {
set str [gets $fh]
append str "\n"
invoked from within
"prnout 1 file7"
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
