Dan Jacobson <jidanni@jidanni.org> wrote:
v.label help mentions p.map, which is gone.
d.paint.labels help also mentions some p things.
g.manual v.label doesn't say what d program one uses to display the labels.
These are fixed as I can see.
And this probably is busted these days:
v.label -a map=contourtest5 column=level labels=contourtest8
Labeled 57 lines.
d.paint.labels labels=contourtest8Dan
Error: rotate: 15.924559...
Without the -a the error messages are gone, but it just draws circles on
the monitor, just the same.
What about this one? Anybody?
P.S.
v.out.ascii contourtest5 out=contourtest99
find ~jidanni/tmp/grassdata -cmin -1
doesn't find anything, nor does -mmin, i.e., v.out.ascii doesn't do anything
anymore.
And this, does anybody know?
Maciek
P.S.
Dan, could you retest and post an update or tell me to close the bug?
