Correction:
This applies not only to GUI as I thought, but to v.surf.rst in general. Why
do we have a default for zcolumn? Should there really be one?
Maciek
P.S.
Changing the subject to "v.surf.rst: zcolumn has a default"
              we put it there as a convenience because flt1 is the default column name if you use
v.in.ascii to import the point data (at least it was the last time I tried it).
This way I can import and interpolate the way I did it
in GRASS5 without checking the column names. I don't think this is a bug, this is a feature.
Helena
On Sep 12, 2005, at 9:25 AM, Maciek Sieczka via RT wrote:
Correction:
Maciek
P.S.
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Helena Mitasova
Dept. of Marine, Earth and Atm. Sciences
1125 Jordan Hall, NCSU Box 8208,
Raleigh NC 27695
http://skagit.meas.ncsu.edu/~helena/
              The zcolumn should not have default value.
Radim
name if you use
tried it).
Helena
> Correction:
> general. Why
> Maciek
> P.S.
> grass5 mailing list
> grass5@grass.itc.it
Helena Mitasova
Raleigh NC 27695
grass5 mailing list
grass5@grass.itc.it
Why not? In interpolation 2D data must always have an attribute (floating point, no categories). This makes sense to me.
Jaro
Radim
name if you use
tried it).
Helena
Correction:
general. Why
Maciek
P.S.
grass5 mailing list
grass5@grass.itc.it
Helena Mitasova
Raleigh NC 27695
grass5 mailing list
grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
              No other 'column' option has a default value.
Column name can be any word, v.in.ascii without definition
of column names is just one possible way to create data
+ it creates columns dbl_1, dbl_2 etc.,
+ if you import x|y|val with v.in.ascii, the column names will be
dbl_1, dbl_2, dbl_3 so it would be necessary to have default
value for z dbl_3. Simply default value for input column name is
not a good idea.
Radim
Jaro
> Radim
>>name if you use
>>tried it).
>>Helena
>>>Correction:
>>>general. Why
>>>Maciek
>>>P.S.
>>>_______________________________________________
>>>grass5 mailing list
>>>grass5@grass.itc.it
>>Helena Mitasova
>>Raleigh NC 27695
>>grass5 mailing list
>>grass5@grass.itc.it
> grass5 mailing list
> grass5@grass.itc.it
