this bug's URL: http://intevation.de/rt/webrt?serial_num=4008
Subject: gism2: Querying the map doesn't work
Platform: GNU/Linux/x86
grass obtained from: CVS
GRASS Version: grass6 cvs 20060117
When trying to query a vector map, an "Application error" window opens, with the detailed message
couldn't execute "v.what": no such file or directory
while executing
"error $fh"
(procedure "run_panel" line 9)
invoked from within
"run_panel $cmd"
(procedure "GmVector::query" line 33)
invoked from within
"GmVector::query $sel $east $north"
("vector" arm line 2)
invoked from within
"switch $type {
raster {
GmRaster::query $sel $east $north
labels {
GmLabels::query $sel $east $north..."
(procedure "GmTree::query" line 11)
invoked from within
"GmTree::query $mon $east $north"
(procedure "mapcan::startquery" line 8)
invoked from within
"mapcan::startquery $mon 520 196"
(command bound to event)
Querying a raster map works ok. From the command line, I can access the executables v.what.vect and v.what.rast but no v.what .
Greetings,
Harri Kiiskinen
