Request Tracker wrote:
this bug's URL: http://intevation.de/rt/webrt?serial_num=4049
Subject: d.m: dozens of d.mon zombies
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
GRASS Version: CVS 2005.01.27
Uisng d.m leads to lots of zombi d.mon processes.
1. grass61 -text
2. d.m
3. ps -A | grep d.mon
19313 pts/2 00:00:00 d.mon <defunct>
4. press "x1" in d.m, or redraw, zoom, pan
5. ps -A | grep d.mon
19340 pts/2 00:00:00 d.mon <defunct>
... and so on.
By the end of Grass session there are dozens of d.mon zombies. Quiting d.m colses them all.
FWIW, I also see lots of g.region zombies.
AFAICT, it's due to the use of "open", e.g.:
gm.tcl:298: if ![catch {open "|d.mon -L" r} input] {
gm.tcl:319: if ![catch {open "|d.mon -L" r} input] {
gm.tcl:385: if ![catch {open "|d.mon -L" r} input] {
gm.tcl:611: if ![catch {open "|d.mon -L" r} input] {
mapcanvas.tcl:233: if ![catch {open "|g.region -g" r} input] {
mapcanvas.tcl:283: if ![catch {open "|d.mon -L" r} input] {
mapcanvas.tcl:436: if ![catch {open "|g.region -g" r} input] {
mapcanvas.tcl:599: if ![catch {open "|g.region -g" r} input] {
mapcanvas.tcl:962: if ![catch {open "|g.region -g" r} input] {
vector.tcl:548: if ![catch {open "|d.mon -L" r} input] {
I can't find a single case which calls "close $input" once the stream
is finished with. I suspect that wish won't actually wait() for the
process until you call close, hence the accumulation of zombies.
BTW, I suspect that most of those "d.mon -L" commands are unnecessary.
You should be unconditionally starting the monitor before drawing
anything and unconditionally stopping it once you're done.
Also, none of the "d.mon start=PNG" commands have the -s switch; this
will interfere with the user's choice of selected monitor. Use -s and
$MONITOR_OVERRIDE instead of modifying $GISRC.
