[GRASS5] [bug #4055] (grass) Skript / module to create new chart vector themes
this bug's URL: http://intevation.de/rt/webrt?serial_num=4055
Subject: Skript / module to create new chart vector themes
Platform: GNU/Linux/x86
grass obtained from: Other (CDROM etc)
grass binary for platform: Downloaded precompiled Binaries
Would be great to have a script/module for creating a chart vector theme. This would make it possible to display charts also in QGIS or other applications (Mapserver!).
Best regards,
Wolfgang Qual
Request Tracker wrote:
this bug's URL: http://intevation.de/rt/webrt?serial_num=4055 -------------------------------------------------------------------------
Platform: GNU/Linux/x86 grass obtained from: Other (CDROM etc) grass
Personally I think that this should always be part of the display and not part of the themes. In ArcView the existing scripts use the theme solution and it is a pain in the * to work with as you have to relaunch it (and create more and more themes) until you get the right size. I think QGIS should deal with this directly...
Moritz
What is the 'theme'?
Radim
Typical ArcView talk (unless I completely misunderstood Wolfgang's original request). In GRASS it would be a "map", i.e. the idea is to create a new map which contains vector features which correspond to the charts. Thus you could display it in QGIS just as if it was any GRASS vector layer...
Moritz
Unless I completely misunderstand this, it already exists--d.vect.chart
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Reply-To: Request Tracker <grass-bugs@intevation.de>
Date: Fri, 3 Feb 2006 12:17:53 +0100 (CET)
To: <grass5@grass.itc.it>
Subject: [GRASS5] [bug #4055] (grass) Skript / module to create new chart
vector themes
(Mapserver!).
Best regards,
Wolfgang Qual
