[GRASS5] [bug #850] (grass) v.dump
this bug's URL: http://intevation.de/rt/webrt?serial_num=850
Are you sure you want it to say all this here?
$ v.dump
OPTION: Unique number of an area,line,site,category, or node
     key: num
required: NO
PROGRAMMER ERROR: first item in gisprompt is <entity number>
        Must be either new, old, mapset, or any
OPTION: vector map(s)
     key: map
required: YES
multiple: YES
Enter the name of an existing vector file
Enter 'list' for a list of existing vector files
Hit RETURN to cancel request
--- Headers Follow ---
From neteler@itc.it Fri Nov 16 16:40:35 2001
Return-Path: <neteler@itc.it>
Delivered-To: grass-bugs@lists.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
  by lists.intevation.de (Postfix) with ESMTP id CC53D139CC
  for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:40:34 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
  by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id fAGFeYf24025
Received: from artemide.itc.it (artemide [10.0.10.10])
  by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFeXd19460
  for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:40:33 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
  by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFeVE19430
  for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:40:31 +0100 (MET)
Received: (from neteler@localhost)
  by thuille.itc.it. (8.11.6/8.11.2) id fAGFeUL29661
  for grass-bugs@intevation.de; Fri, 16 Nov 2001 16:40:30 +0100
Resent-Message-Id: <200111161540.fAGFeUL29661@thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
  by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMWE16793
  for <neteler@itc.it>; Fri, 16 Nov 2001 16:22:36 +0100 (MET)
Received: from localhost.localdomain (h137.s30.ts32.hinet.net [163.32.30.137])
  by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMQd18915
  for <neteler@itc.it>; Fri, 16 Nov 2001 16:22:26 +0100 (MET)
Received: by localhost.localdomain (Postfix, from userid 501)
  id 4836F16D9; Fri, 16 Nov 2001 19:58:30 +0800 (CST)
To: Markus Neteler <neteler@itc.it>
Subject: v.dump
Reply-To: jidanni@yahoo.com.tw
Date: Fri, 16 Nov 2001 19:58:29 +0800 01:00:00 +0000 (GMT)
Message-ID: <m2g07f2ahm.fsf@Mdan.jacobson.tw>
User-Agent: Gnus/5.0808 (Gnus v5.8.8) Emacs/20.7
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Resent-From: neteler@itc.it
Resent-Date: Fri, 16 Nov 2001 16:40:30 +0100
Resent-To: grass-bugs@intevation.de
