this bug's URL: http://intevation.de/rt/webrt?serial_num=871
On Thu, Dec 13, 2001 at 11:53:35AM +0100, Morten Hulden wrote:
Hi Markus,
this is not on the artifacts but on the 1-pixel shift:
On Wed, 12 Dec 2001, Markus Neteler wrote:
> - might be shifted by 0.5 to 1 pixel (not sure!)
I suggested a fix for this, Markus. Did you try it?
Hi Morten,
sorry, I did not try (at time in Germany away from my data).
I have been looking at that code portion and was not sure
about it (the confusing index).
I will apply the bugfix now.
> In r.proj/cmd subroutines nearest.c (and bipolar.c and cubic.c) change
> the lines> row = (int) (*row_idx + 0.5);
> col = (int) (*col_idx + 0.5);> to
> row = (int) (*row_idx);
> col = (int) (*col_idx);> If this helps, of course the correct fix would be to delete the lines
> from the subroutines altogether, and make the type cast in main.c
> instead, and declare row_idx and col_idx as integers. (row_idx and
> col_idx are not used as floats anywhere, so why declare them as such.
> but changing them requires changes in function declarations and
> r.proj.h as well, so go for the easy test above first)I am very sorry but I cannot get my grass installation to work so right
now I can't test it myself, though I would really like to get it going
again.But I have very little time to play with the installation process. How do
you get the socket-driver to work? Shouldn't there be a makesockets.sh
script included somewhere?
The socket driver is default and plug-and-play nowadays. Do
you face problems to get it running?
--- Headers Follow ---
From neteler@itc.it Thu Dec 13 15:14:32 2001
Return-Path: <neteler@itc.it>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 2D5D313A03
for <grass-bugs@lists.intevation.de>; Thu, 13 Dec 2001 15:14:32 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by mail.intevation.de (Postfix) with ESMTP id 57CA51B77C
for <grass-bugs@intevation.de>; Thu, 13 Dec 2001 15:14:31 +0100 (CET)
Received: from artemide.itc.it (artemide [10.0.10.10])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fBDEEPd25315;
Thu, 13 Dec 2001 15:14:25 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fBDEEN727376;
Thu, 13 Dec 2001 15:14:23 +0100 (MET)
Received: (from neteler@localhost)
by thuille.itc.it. (8.11.6/8.11.2) id fBDEEMZ05709;
Thu, 13 Dec 2001 15:14:22 +0100
Date: Thu, 13 Dec 2001 15:14:22 +0100
To: Morten Hulden <morten@ngb.se>
Cc: grass-bugs@intevation.de,
grass5 developers list <grass5@grass.itc.it>
Subject: Re: r.proj problem: boxes appearing
Message-ID: <20011213151422.E5660@itc.it>
Mail-Followup-To: Morten Hulden <morten@ngb.se>, grass-bugs@intevation.de,
References: <20011212162152.A4293@itc.it> <Pine.LNX.4.33.0112131145080.15636-100000@tor.ngb.se>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
User-Agent: Mutt/1.2.5i
In-Reply-To: <Pine.LNX.4.33.0112131145080.15636-100000@tor.ngb.se>; from morten@ngb.se on Thu, Dec 13, 2001 at 11:53:35AM +0100
X-Spam-Status: No, hits=0 required=5 tests=
