this bug's URL: http://intevation.de/rt/webrt?serial_num=928
Subject: d.area-tcltkg3.2: Failed color lookup for
Platform: Linux/Intel
Linux distro: Mandrake
linux cpu: Intel (i486, i586, pentium ...)
Xwindows version: Xfree 4.0.x
Xwindows manager: KDE 2.x
TclTk version: tcl/tk 8.0
grass downloaded at: Trento site
grass binary for platform: I compiled the sources myself
grass sources source: no, I got a source code package from the server,
grass5.0.0pre3
c compiler name: gcc
d.area Tcltkgrass(3.2) menu permits lists 'indigo' as Polygone border & fill
color, but seems not to be implemented with d.area.
Note: 'indigo' works fine with e.g. d.vect.
Karine ZUERCHER <kzuerch@yahoo.com>
grass5.0.0pre3
In a misguided attempt to add flexibility, I made d.area use X11 color
names. Unfortunately, the TclTkGrass interface was not updated to
reflect this. X11 has no named color of indigo. You might like
DodgerBlue though ;-0.
Note: d.area has been deprecated in CVS, the replacement uses
standard GRASS named colors (or RGB).
Eric G. Miller <egm2@jps.net>
